i did this in the dim distant past to control an 8x8 rgb matrix with a pic18f252.
i reconsider your statement about the wires seeming right, since the only firmware change is changing a loop counter from 16 to 24.
How can I control 40 relays?
Re: How can I control 40 relays?
Thanks again for all your help everybody.
I have the circuit working now and thought I would share the solution.
I have 40 5v relays wired to 5 daisy chained 74HC595N Chips, controlled by an Arduino micro controller. For the control of 40 5v reed relays the ULN2803 chip was not needed.
The circuit worked when I connected the first chip to the last on the power rail, then connected the last to the ones in between.
Like the 74HC595 you can use a CD4094 shift register.
I'm using a CD4094 shift register and BC548 transistors to drive 5V relays, works perfectly. The outputs from the 4094 are connected to the base of the BC548 through a 1k resistor, emitter connected to the ground, collector connected in series with the relay spool to +5V. A 1N4004 diode is connected in parallel in inverted position to the relay for protection. Using this configuration draws some current so I don't use the Arduino's power line to drive the relays, using an external power supply for that purpose.
can you please share the detail diagram on this ?
thanks.
Rgds,
iwan
thanks.
Rgds,
iwan
wgrube wrote:Like the 74HC595 you can use a CD4094 shift register.
