fade neopixel
bror
fade neopixel
Post by bror »
hi, is possible to apply a fade to the "simple" example provided by the Adafruit library?
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN            6
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS      16
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 500; // delay for half a second
  pixels.begin(); // This initializes the NeoPixel library.
  // For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
  for(int i=0;i<NUMPIXELS;i++){
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    pixels.setPixelColor(i, pixels.Color(0,150,0)); // Moderately bright green color.
    pixels.show(); // This sends the updated pixel color to the hardware.
    delay(delayval); // Delay for a period of time (in milliseconds).
adafruit_support_mike
Re: fade neopixel
Sure. The easiest way to do it would be with pixels.setBrightness(), which accepts values from 0 to 255 as input.
The one trick is that a straight fade from 0 to 255 won't look very good. The human eye sees brightness in terms of ratios rather than absolute values, so 'twice as much light' looks the same whether it's a step from 1 to 2 or from 128 to 256.
To get a smooth-looking fade you need to use the sequence 1, 2, 4, 8, 16, etc.
bror
Re: fade neopixel
Post by bror »
   pixels.setBrightness(150); // Moderately bright green color.
nothing has changed .. :(
i want this effect https://youtu.be/cqMnpVlkpUA?t=12s, the loop I think I know the problem is to do animation.
Re: fade neopixel
Take a look at our Larson Scanner Shades tutorial: https://learn.adafruit.com/larson-scanner-shades
It produces the same kind of effect.
bror
Re: fade neopixel
Post by bror »
I tried to change "pos" but the animation is always the same, I inserted -2 to see if it made an animation only from below to above,
also can not figure out how to change the color because I do not find the usual pattern with set.pixelcolor (i, R, G, B)
#define N_LEDS  8
#define PIN     6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
int pos = 0, dir = 1; // Position, direction of "eye"
  int j;
  // Draw 5 pixels centered on pos.  setPixelColor() will clip any
  // pixels off the ends of the strip, we don't need to watch for that.
  strip.setPixelColor(pos - 2, 0x100000); // Dark red
  strip.setPixelColor(pos - 1, 0x800000); // Medium red
  strip.setPixelColor(pos    , 0xFF3000); // Center pixel is brightest
  strip.setPixelColor(pos + 1, 0x800000); // Medium red
  strip.setPixelColor(pos + 2, 0x100000); // Dark red
  strip.show();
  delay(30);
  // Rather than being sneaky and erasing just the tail pixel,
  // it's easier to erase it all and draw a new one next time.
  for(j=-2; j<= 2; j++) strip.setPixelColor(pos+j, 0);
  // Bounce off ends of strip
  pos += dir;
  if(pos < 0) {
    pos = 1;
    dir = -dir;
  } else if(pos >= strip.numPixels()) {
    pos = strip.numPixels() - 2;
    dir = -dir;
bror
Re: fade neopixel
Post by bror »
could someone help me please? :(
Re: fade neopixel
What exactly are you trying to do?
That is just another form of the same function. If you prefer to work with explicit RGB values, you can replace the existing setpixelcolor calls and specify whatever RGB values you like.
bror
Re: fade neopixel
Post by bror »
i want to replace this effect :)
Re: fade neopixel
This is the part you need to change:
  pos += dir;
  if(pos < 0) {
    pos = 1;
    dir = -dir;
    dir = -dir;
You want to keep the same 'dir' and reset 'pos' to zero when it gets to the end:
  // Reset at end of strip
  pos += 1;
 .if(pos >= strip.numPixels())
    pos = 0;
Return to “Arduino”
