any thoughts on generating a procedure that would use the timer to create a software PWM signal on the digital pins? Seems simple enough in principle, after all PWM is a digital signal....
Just doing cost/benefit analysis- If i want individual control over the maximum # of LED's for fading purposes, -Im just thinking that a arduino+say a tlc5940 gives you about 16 PWM signals, but a stand alone Atmega 168 could potentially have 14 if you could convert the digital ones- run it through a transistor array chip and I think the cost per channel would be pretty cheap in terms of $$ (maybe expensive in terms of processing_) but simpler in a way.
Why haven't seen this anywhere? Am I missing something?
R
