I have a RGB LED Strip, which I control via an Arduino and some TIP's. Now, I want to control it with a Remote. So, i modified the original code a little bit, but I get an error. Can someone please help me? Here's the code;
#include <IRremote.h>
#define REDPIN 9
#define GREENPIN 10
#define BLUEPIN 11
#define FADESPEED 25 // make this higher to slow down
#define code1 63495 // code received from button A
#define code2 30855 // code received from button B
#define code3 22695 // code received from button C
int RECV_PIN = 3; // the pin where you connect the output pin of TSOP4838
int led1 = 2;
int led2 = 4;
int led3 = 7;
int itsONled[] = {0,0,0,0};
IRrecv irrecv(RECV_PIN);
decode_results results;
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
Serial.begin(9600); // you can comment this line
irrecv.enableIRIn(); // Start the receiver
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
int r, g, b;
// fade from blue to violet
for (r = 0; r < 256; r++) {
analogWrite(REDPIN, r);
delay(FADESPEED);
// fade from violet to red
for (b = 255; b > 0; b--) {
analogWrite(BLUEPIN, b);
delay(FADESPEED);
// fade from red to yellow
for (g = 0; g < 256; g++) {
analogWrite(GREENPIN, g);
delay(FADESPEED);
// fade from yellow to green
for (r = 255; r > 0; r--) {
delay(FADESPEED);
// fade from green to teal
for (b = 0; b < 256; b++) {
delay(FADESPEED);
// fade from teal to blue
for (g = 255; g > 0; g--) {
delay(FADESPEED);
//TESTING LINE AHEAD
if (irrecv.decode(&results)) {
unsigned int value = results.value;
switch(value) {
case code1:
if(itsONled[1] == 1) { // if first led is on then
digitalWrite(led1, LOW); // turn it off when button is pressed
itsONled[1] = 0; // and set its state as off
} else { // else if first led is off
digitalWrite(led1, HIGH); // turn it on when the button is pressed
itsONled[1] = 1; // and set its state as on
break;
case code2:
if(itsONled[2] == 1) {
digitalWrite(led2, LOW);
itsONled[2] = 0;
} else {
digitalWrite(led2, HIGH);
itsONled[2] = 1;
break;
case code3:
if(itsONled[3] == 1) {
digitalWrite(led3, LOW);
itsONled[3] = 0;
} else {
digitalWrite(led3, HIGH);
itsONled[3] = 1;
break;
Serial.println(value); // you can comment this line
irrecv.resume(); // Receive the next value
Arduino: 1.6.3 (Windows 7), Board:"Arduino Uno"
RGB_LED_Strip_control.ino: In function 'void loop()':
RGB_LED_Strip_control.ino:103:3: error: expected '}' at end of input
Thanks in advance!
-Politeguy
