Correction of a crooked cylinder
bdellal
Re: Correction of a crooked cylinder
Post by bdellal »
I ran into a problem with the while loop:
The actuators are moving too fast for the electronics to react. I wonder if this is just because of inefficient programming or if the arduino hits its borders here.
This is (one of) my while loop(s):
while (vectorChange < 0.05) { // while the length is decreasing
                      //TAKE MEASUREMENTS
                      int i;
                      for(i = 0; i<filter; i++)  {
                      analog_read_value_1 += analogRead(sensor_1);
                      analog_read_value_1 /=(filter+1);
                      sensor_voltage_1 = analog_read_value_1/1023*5;
                      distance_1 = -0.117190880571932 * pow(sensor_voltage_1, 0) +  0.543037208594546 * pow(sensor_voltage_1, 1) +  0.233122218845504 * pow(sensor_voltage_1, 2) + -0.0743638185159096 * pow(sensor_voltage_1, 3) +  0.00956562734274045 * pow(sensor_voltage_1, 4);
                      int j;
                      for(j = 0; j<filter; j++)  {
                      analog_read_value_2 += analogRead(sensor_2);
                      analog_read_value_2 /=(filter+1);
                      sensor_voltage_2 = analog_read_value_2/1023*5;
                      distance_2 = -0.117190880571932 * pow(sensor_voltage_2, 0) +  0.543037208594546 * pow(sensor_voltage_2, 1) +  0.233122218845504 * pow(sensor_voltage_2, 2) + -0.0743638185159096 * pow(sensor_voltage_2, 3) +  0.00956562734274045 * pow(sensor_voltage_2, 4);
                      int k;
                      for(k = 0; k<filter; k++)  {
                      analog_read_value_3 += analogRead(sensor_3);
                      analog_read_value_3 /=(filter+1);
                      sensor_voltage_3 = analog_read_value_3/1023*5;
                      distance_3 = -0.117190880571932 * pow(sensor_voltage_3, 0) +  0.543037208594546 * pow(sensor_voltage_3, 1) +  0.233122218845504 * pow(sensor_voltage_3, 2) + -0.0743638185159096 * pow(sensor_voltage_3, 3) +  0.00956562734274045 * pow(sensor_voltage_3, 4);
                      int l;
                      for(l = 0; l<filter; l++)  {
                      analog_read_value_4 += analogRead(sensor_4);
                      analog_read_value_4 /=(filter+1);
                      sensor_voltage_4 = analog_read_value_4/1023*5;
                      distance_4 = -0.117190880571932 * pow(sensor_voltage_4, 0) +  0.543037208594546 * pow(sensor_voltage_4, 1) +  0.233122218845504 * pow(sensor_voltage_4, 2) + -0.0743638185159096 * pow(sensor_voltage_4, 3) +  0.00956562734274045 * pow(sensor_voltage_4, 4);
                       y_1 = distance_1 + r + sensor_2_y_position;
                       y_2 = distance_2 + r + sensor_2_y_position;
                       x_1 = distance_3 + r;
                       x_2 = distance_4 + r;
                       vector_length = sqrt( sq(x_2-x_1) + sq(y_2-y_1));
                       x_1_center = x_1 - 114.08;
                       x_2_center = x_2 - 114.08;
                       direct = atan2((y_2 - y_1),(x_2_center - x_1_center));
                      //ACTUATE CYLINDER
                      digitalWrite..... ACTUATION
                      vectorChange = vector_length - oldLength;
                      oldLength = vector_length;
                      if (vector_length < max_tolerance)  {
                        break;
So, what my intention was:
What is happening most of the time:
Any suggestions? I cannot slow the actuators down more.
Not sure what you are intending there. But the code looks like it is trying to do straight on/off control. I think what you may need is some PID control.
http://brettbeauregard.com/blog/2011/04 ... roduction/
bdellal
Post by bdellal »
Like I said earlier, I am intending to to catch the moment when my measured value switches from decreasing to increasing again.
If I understood it right, a PID controller would keep my system close to a desired setpoint. I am not sure how to use that for my problem.
bdellal
Post by bdellal »
I don't know what mode of 'actuation' you are using. But mechanical systems follow physical laws and don't start and stop instantaneously. You need to slow down as you approach the desired position or you will overshoot.
You want your actuation force to be proportional (the P in PID) to the error (distance from the minimum point).
bdellal
Post by bdellal »
I am using an hydraulic cylinder to push on a part to straighten it. I understand that I will overshoot maybe but I want to keep the overshoot as small as possible and with my current method, the misalignment jumps from:
0.51
0.48
0.40
0.22
1.15
I would like it to look like:
0.51
0.48
0.40
0.22
0.30
I think my control loop would be fine, if my measurement resolution would be high enough.
Can you slow down the actuators?
bdellal
Post by bdellal »
No, unfortunately not. I already slowed them down as much as possible.
bdellal
Post by bdellal »
What do you think about that?
//PID
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
int WindowSize = 100;
unsigned long windowStartTime;
  //Variables used for PID
  //initialize the variables we're linked to
  windowStartTime = millis();
  Setpoint = 0;
  //tell the PID to range between 0 and the full window size
  myPID.SetOutputLimits(0, WindowSize);
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
  myPID.SetSampleTime(50);
                      //PID
                      Input= vectorChange;
                      myPID.Compute();
                       * turn the output pin on/off based on pid output
                      unsigned long now = millis();
                      if(now - windowStartTime>WindowSize)
                          { //time to shift the Relay Window
                          windowStartTime += WindowSize;
                      if(Output > now - windowStartTime)   {
                          //ACTUATE CYLINDER
                          digitalWrite(valve_2_push, HIGH);
                          digitalWrite(valve_3_push, HIGH);
                          digitalWrite(valve_4_push, HIGH);
                          digitalWrite(valve_5_push, HIGH);
                          digitalWrite(valve_6_push, HIGH);
                          digitalWrite(valve_2_pull, LOW);
                          digitalWrite(valve_3_pull, LOW);
                          digitalWrite(valve_4_pull, LOW);
                          digitalWrite(valve_5_pull, LOW);
                          digitalWrite(valve_6_pull, LOW);
                          digitalWrite(valve_1_push, LOW);
                          digitalWrite(valve_1_pull, HIGH);
                          pullback = 1;
The real question is how does it work? I don't know how well your actuators respond to time-proportional-outputs or pulse-width modulation.
Return to “Arduino”
