AVRDUDE not working + touch shield
brooklync
Post by brooklync »
I'm trying to upload a sketch that uses the TFT touch shield. The sketch uploads without error when the shield is not connected. However, when the shield is connected, the compiler returns this error:
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x00 != 0x0c
avrdude: verification error; content mismatch
I believe there is a problem with the bootloader. Can anybody help me solve this problem? Thanks.
Franklin97355
Re: AVRDUDE not working + touch shield
Post by Franklin97355 »
Since the code loads without the shield the bootloader is working (it's on the Arduino) You may have a short on the shield, could you post large (less than 1meg,~800x600), clear, detailed pictures of both sides of your board showing any soldering you have done?
brooklync
Post by brooklync »
I figured out that it wasn't working because the touch shield pins weren't fully connected to the arduino. Thanks!
Return to “Arduino”
