I am looking for some help with interfacing a Joystick with a Stepper motor that will allow me to actuate the joystick (X+ / X-) causing the stepper to move a specific number of steps. I've looked around and muddled with my code (that Actuates the stepper continuous when the Joystick is moved) but can't figure what to code to get specific steps. Any help would be greatly appreciated and marked into the "Beer Payment" book.
Thanks in advance.
Joystick and Stepper Motor Question
- Franklin97355
Re: Joystick and Stepper Motor Question
Perhaps, if you post your code and a description or drawing of your connections between it all we can help. Please use the code button "</>" or
tags when posting code to the forums.
- HREFAB
Thanks for the quick reply. I found this code on another site and chopped it up to work (partially) in the way I envision. I have it where the Joystick will actuate CW and CCW depending on the direction, but what I can't figure is how to get it to only move the stepper a certain number of steps. I tried commenting out some of the STEP++ comments and via trial and error I managed to get the joystick to work.
I'm sure that my code has superfluous bits and bobs in it, but I'm just baffled as to how to declare the number of steps (I should mention that I have a sketch that works without the joystick, but When I incorporate it into the sketch/schematic, I can't replicate that behavior.)
I"m also pretty sure that I have more code here than is necessary, but I left the body of it in as it's ALMOST doing what I want. Any suggestions or advice is much appreciated.
Here's the code that I am using; (I edited this tonight after I cleaned up some un-necessary bits...This is now running ALMOST the way I want, I just need to understand how to make the Joystick Control the Steps of the Stepper Motor).
#define step_pin 3 // Pin 3 connected to Steps pin on EasyDriver
#define dir_pin 2 // Pin 2 connected to Direction pin
#define MS1 5 // Pin 5 connected to MS1 pin
#define MS2 4 // Pin 4 connected to MS2 pin
#define SLEEP 7 // Pin 7 connected to SLEEP pin
#define X_pin A0 // Pin A0 connected to joystick x axis
int direction; // Direction CW/CCW
int steps = 1025; // Value from original Code
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(dir_pin, OUTPUT);
pinMode(step_pin, OUTPUT);
pinMode(SLEEP, OUTPUT);
digitalWrite(SLEEP, HIGH); // Wake up EasyDriver
delay(5); // Wait for EasyDriver wake up
/* Configure type of Steps on EasyDriver:
// MS1 MS2
// LOW LOW = Full Step //
// HIGH LOW = Half Step //
// LOW HIGH = A quarter of Step //
// HIGH HIGH = An eighth of Step //
digitalWrite(MS1, LOW); // Configures to Full Steps
digitalWrite(MS2, LOW); // Configures to Full Steps
while (analogRead(X_pin) >= 0 && analogRead(X_pin) <= 100) {
if (steps > 0) {
digitalWrite(dir_pin, HIGH); // (HIGH = anti-clockwise / LOW = clockwise)
digitalWrite(step_pin, HIGH);
delay(1);
digitalWrite(step_pin, LOW);
delay(1);
//steps--;
while (analogRead(X_pin) > 900 && analogRead(X_pin) <= 1024) {
if (steps < 2050) {
digitalWrite(dir_pin, LOW);
delay(1);
delay(1);
//steps++;
- HREFAB
And here is the way the boards are configured; The UNO has to be powered by a %V supply while the Stepper gets its power independently from a 12VDC Lipo Pack.
- Franklin97355
Your code is telling the stepper to move while the joystick is in a certain position but you have no code to do this for a set number of steps. If you want it to do 10 steps and wait your code needs to reflect that. Can you explain in detail what the code should be doing when you move the joystick?
- HREFAB
What I am trying to accomplish is to have the stepper motor move a pre-determined number of steps when the joystick is pushed to the right or the left. Depending on the direction, I would like the stepper to run either CW or CCW. I uploaded some amended code (nothing really different than the original) that has some snipping done of code that wasn't necessary.
Now when I press the Joystick to the left, the motor runs counterclockwise until I release the joystick. If I press the Joystick to the right, it runs CW.
I may be asking the joystick to do something that it is incapable of doing and might be better off with a switch, but i thought I would try to make a go of it as I have gotten this far. If I have to code for a simple switch I may have to leap out the window...and as it's on the ground level, I'll just make the neighbors snicker....
- Franklin97355
if (steps > 0) {
delay(1);
delay(1);
//steps--;
You need to check stick, do action and check stick until center then go back to the loop function.
- HREFAB
OK then. I will figure out how to get the numbers ( I know there is a tutorial so I'll dig it up) and then see what I can come up with.
I appreciate you sticking with me here.
