Using the 128x32 SPI OLED graphic display with the Arduino Z
twosocks
Post by twosocks »
I'm trying to use Adafruit's 128x32 SPI OLED graphic display driver with the Arduino Zero board, but I get compile errors.
Seems to work fine with the Arduino UNO board. Any help is very much appreciated!
Franklin97355
Re: Using the 128x32 SPI OLED graphic display with the Ardui
Post by Franklin97355 »
Probably because you are trying to use libraries designed for the AVR processors and the Zero isn't one of those. Check the Arduino.cc forums to see if anyone has ported a library to work with this board.
Return to “Arduino”
