First time posting
And am just loving my arduino-uno, it's number Awesome!!!
Am putting together a weather station with moving dials and everything
so far got the seven-segmented led display working
And I got the humidity/temp sensor to work
***all without burning up my UNO***
But I'm having problems with:
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp: In member function ‘void Adafruit_BMP280::write8(byte, byte)’:
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp:102:11: error: ‘class SPIClass’ has no member named ‘beginTransaction’
SPI.beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0));
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp:102:67: error: ‘SPISettings’ was not declared in this scope
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp:108:11: error: ‘class SPIClass’ has no member named ‘endTransaction’
SPI.endTransaction(); // release the SPI bus
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp: In member function ‘uint8_t Adafruit_BMP280::read8(byte)’:
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp:130:11: error: ‘class SPIClass’ has no member named ‘beginTransaction’
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp:130:67: error: ‘SPISettings’ was not declared in this scope
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp:136:11: error: ‘class SPIClass’ has no member named ‘endTransaction’
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp: In member function ‘uint16_t Adafruit_BMP280::read16(byte)’:
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp:159:11: error: ‘class SPIClass’ has no member named ‘beginTransaction’
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp:159:67: error: ‘SPISettings’ was not declared in this scope
/home/vic0/sketchbook/libraries/Adafruit_BMP280/Adafruit_BMP280.cpp:165:11: error: ‘class SPIClass’ has no member named ‘endTransaction’
I don't know what's going on. I may try finding a different library for this if I can.
Having lots of fun though, it's great, Lights up changes the display over and over, and Works Great!!!
