I bought the kit METRO and FONA 3G Europe. I have the assembly as on the tutorial but when I launch the program I have this error.
I have not bad to look for the solution on the forum but I do not understand what does not go.
Needs it necessarily a battery so that works?
Here is my assembly:
[Solved] Couldn't find FONA - METRO FONA 3G
- xenonmax
- adafruit_support_rick
Re: Couldn't find FONA - METRO FONA 3G
The FONA requires a battery. The USB power is only for charging the battery - it does NOT power the FONA.
- xenonmax
Thanks Rick,
I am going to test that from Wednesday and then I will make a return if everything works well.
You should use at least a 1200mAh LiPo battery:
https://www.adafruit.com/product/258
- xenonmax
I bought on your site a battery, and now I can see the flashed red led (200ms/200ms).
But when I connect my computer on METRO, and start program, it says that he does not find FONA.
I verified the assembly and the welds but I do not still find the problem.
Can you help me please ?
FONA basic test
Initializing....(May take 3 seconds)
---> AT
---> AT
---> AT
---> ATE0
---> ATE0
Couldn't find FONA
Please post clear, detailed pictures of both sides of the FONA, showing your soldering and wiring
- xenonmax
Here some photos:
Thank you in advance for your help.
Here some photos:
- xenonmax
I found!
In the script, you shouldn't use the line:
With this line, that works:
Even if I have the model FONA 3G.
Thank you anyway for your help!
// Use this one for FONA 3G
//Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
// Use this for FONA 800 and 808s
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
Re: [Solved] Couldn't find FONA - METRO FONA 3G
That's just not right. You'll probably have some problems with this, since there are some differences in the 3G commands. I don't understand why it won't work with Adafruit_FONA_3G. I'll see what I can find out.
- adafruit2
did you remember to fix the baud rate?
- mimosa
so what's the baud rate that works with the FONA board?
- adafruit2
- Prostar
I recently read your posts and I seem to be having similar problems. All the wires have been soldered correctly and there is a battery attached however when I upload the fona test code it comes up with couldn't find fona. I tried changing the code to run the font rst but it didn't work either.
Please help
Thanks in advance
Please help
Thanks in advance
Please post some pictures showing your soldering and wiring.
Also, post the exact output from Serial Monitor
- Prostar
I apologise for the late response. I have been quite busy with other work so I haven't been able to work on my arduino project much. Anyway here is a link to the pictures of my arduino project. They are on imager because I couldn't seem to upload them on this reply. http://imgur.com/a/MFb97
