Hi everyone,
I'm trying to take a snapshot with the camera and save the image with the SD Breakout Board. The program recognise the board, but i don't know why it doesn't recognise the camera, it always says "camera not found?", and i don`t know what the problem is. Everything is connected on its due place, I use the snapshot model provided on Adafruit's Github. It happens the same with the VC0706 Comm Tool.
I've attached the image of the circuit which i use and the program on a textfile, the circuit it's the same as the one used on the homepage, with the difference that I use an Arduino Uno instead of the Duemilanove.
Camera Not Found?
- JonaDC
Camera Not Found?
- Program.txt
- Arduino Program
- (6.37 KiB) Downloaded 129 times
- Circuit
- camara-jpeg-ttl.jpg (83.03 KiB) Viewed 562 times
Re: Camera Not Found?
Post a photo showing the connections for your hardware please. We know the one in the photo works, so it doesn't give us any useful information about the problem. 800x600 images usually work best.
- JonaDC
Hi Mike, sorry for the lateness.
I attach two pictures in different views. I hope you can see the connections clearly.
Thanks.
Thanks.
- 2.jpg (140.25 KiB) Viewed 497 times
- 1.jpg (157.02 KiB) Viewed 497 times
Try moving your GND connection over to the hole in line with the 5v, RX, and TX pins.
IIRC, that board has some non-obvious connections.
- JonaDC
Hi Mike,
I did what you told me and is not working yet. It's all connected on its right place, I've checked all with the multimeter so I don't know why it's not working.
Your other connections look good, so we'll have to call this one a dead camera.
How long have you had the camera?
- JonaDC
Since june, but i never got to make it work.
I'm afraid that's well past our 30-day return/replace window.
- JonaDC
Thanks for your help Mike but, are you really sure that the camera is dead? I mean, is there any option to test it?. Just to be totally sure.
If you have a display that can take NTSC/PAL input, like an old disc player, you can try hooking up that output from the camera board and seeing if it produces video that way.
- JonaDC
Hi Mike,
I know its been a while since the last time we spoke, sorry for the lateness. I did what you told me and the output of the video is working, so I guess that the camera is not dead yet, right? What's the problem then?
Apparently the camera and its NTSC/PAL output system are good, but the Serial output system is dead.
- JonaDC
Hi Mike,
I've had the chance to check with an oscilloscope the serial system pins of the camera. As you can see in the photos, the camera receives the pulse sequence and immediately sends back a train pulse. Ive checked directly in the pin of the ATMEGA and it receives this signal, so what's then the problem? Could it be incompatibility with the operative system or maybe the software it's not correctly configured?
- TX_CAM.jpg (177.38 KiB) Viewed 290 times
- RX_CAM.jpg (162.79 KiB) Viewed 290 times
Try connecting the camera to pins 0 and 1 and using the Arduino as a pass-through converter for the CommTool that's linked from the tutorial. See if you can get it to respond that way.
