Motor shield v2 won't work
- JyoP
Hi, I am a big fan of Adafruit, but recently my motor shield v2 doesn't work anymore. It was working fine before and all of a sudden it stopped working. I would like a replacement, because I have tried everything to make it work, I checked all the solder connection, and made sure all the wiring was correct. And it was all good.
- adafruit_support_mike
Re: Motor shield v2 won't work
How long have you had the Motor Shield?
What motors and power supply are you using with the shield?
- JyoP
Um, I am using 9 volts for powering just the shield. And I am using an adafruit Stepper motor that was meant to work with the sheild.
When did you purchase the shield?
Please post photos showing your soldering and connections to the shield.
- JyoP
I purchased it about a month ago.
- JyoP
umm ok give me a day.
- doublejosh
Hope you're not using a 9V battery when you say "powering just the shield with 9V." That won't work.
I'm having what seems to be a similar problem with my Motor shield 2.3
- doublejosh
(deleting reply)
@doublejosh - please start a new thread for your issue.
- doublejosh
Thanks, did so and cleaned details out of this thread.
viewtopic.php?f=25&t=84733
