Can't get Arduino IDE to work with new purchase Feather
DaveMark
Post by DaveMark »
Help please! I followed your guide https://learn.adafruit.com/add-boards-a ... 4?view=all but when I compile I get...
Arduino: 1.6.4 (Mac OS X), Board: "Adafruit Feather M0 (Native USB Port)"
Build options changed, rebuilding all
{runtime.tools.arm-none-eabi-gcc.path}/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10604 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON -DUSB_MANUFACTURER="Adafruit" -DUSB_PRODUCT="Feather M0" -I{runtime.tools.CMSIS.path}/CMSIS/Include/ -I{runtime.tools.CMSIS.path}/Device/ATMEL/ -I/Users/daveturk/Library/Arduino15/packages/adafruit/hardware/samd/1.0.3/cores/arduino -I/Users/daveturk/Library/Arduino15/packages/adafruit/hardware/samd/1.0.3/variants/arduino_zero /var/folders/dk/r7556ww12j5bwjnmhfxqk7sr0000gr/T/build5828133780708300997.tmp/sketch_nov27a.cpp -o /var/folders/dk/r7556ww12j5bwjnmhfxqk7sr0000gr/T/build5828133780708300997.tmp/sketch_nov27a.cpp.o
Cannot run program "{runtime.tools.arm-none-eabi-gcc.path}/bin/arm-none-eabi-g++" (in directory "."): error=2, No such file or directory
Franklin97355
Re: Can't get Arduino IDE to work with new purchase Feather
Post by Franklin97355 »
Try re-downloading the software. It seems one of the files needed can't be found by the compiler.
DaveMark
Post by DaveMark »
franklin97355 wrote:Try re-downloading the software. It seems one of the files needed can't be found by the compiler.
Hi thanks, if you mean the IDE, I tried downloading 1.6.6, unzipped it, but will not launch. i.e. Nothing!
Will try 1.6.4 again: https://www.arduino.cc/en/Main/OldSoftw ... s#previous
Franklin97355
1.6.6 seems to have problems, at least on windows it does.
DaveMark
Post by DaveMark »
franklin97355 wrote:1.6.6 seems to have problems, at least on windows it does.
Hi thanks, but I'm using Mac.
Fresh 1.6.4
Fresh 1.6.6 Which I got working now.
Same problem on both, still not compiling.
Ideas?
BTW Around 12 hours ago, a friend got it working on his Mac, no idea what's wrong in my case.
Franklin97355
Post the output of the compile using the verbose option in the preferences.
DaveMark
Post by DaveMark »
franklin97355 wrote:Post the output of the compile using the verbose option in the preferences.
I did! See above in my first post of the thread.
DaveMark
Post by DaveMark »
DOOOOOH!!!
Had wrong board selected.
Pretty lame excuse :(
<Walks away disgraced!>
It LIVES :)
Return to “Arduino”
