I have a couple of the Adafruit RFM95W LoRa Radio Transceiver Breakout - 868 MHz in the post and I was wondering if it is possible to change the network ID and node number in the main loop? I want to write a code where modules can be reconfigured to connect to different network without restarting, is this possible?
Thanks in advance!
RFM95 RFM69 Change NETWORKID in loop
- Franklin97355
Re: RFM95 RFM69 Change NETWORKID in loop
The datasheet might give you some ideas.http://www.hoperf.nl/Files/3/1000/1211/ ... 8k6s7h.pdf
