Cheap product enclosuers?
Get help, and assist others in with open source kits and running a business! Do not ask for legal advice or for consulting services in this forum, only general biz questions!
by cstratton on Mon Aug 20, 2012 5:58 pm
Not technically a kit question, but figured this was the closest topic area -
Anyone know where to get very small, very cheap "project boxes" suitable for a short-run (25-100 pcs) product? I need to enclose a little 2 square inch PCB in something that can be opened occasionally, so it would need to be a screw together or snap together type solution - potting and heatshrink are out.
I have a slide-cover 2xAA battery holder on my desk that is almost perfect... if not for the need to yank/carve out the battery holding components.
Re: Cheap product enclosuers?
by lyndon on Tue Aug 21, 2012 1:15 pm
If you're going to ask for "very cheap" and "very small" it is helpful to put some numbers down. Not everyone will use the same criteria you do.
The cheapest plastic enclosure I know of is PVC pipe with endcaps. Pipe is about $2/10 feet and endcaps run around $0.35 each.
by john444 on Tue Aug 21, 2012 1:33 pm
Hi Cstratton,
General merchendice stores carry small plastic containers.
I am specifically thinking of the travel containers for bars of soap.
They have a snap clasp and are large enough to contain your 2" board.
In addition, they are fairly inexpensive.
Good luck, John
