Wanted: Octave Cat / Kitten White Knob & Silver Slider Cap
- e:pp:ik
... if by chance one of you has a magical bin filled with these parts
Re: Wanted: Octave Cat / Kitten White Knob & Silver Slider Cap
Got a pic of what it looks like? I have 69 gazillion buttons, knobs, slider caps, etc. here.E:pp:ik wrote:... if by chance one of you has a magical bin filled with these parts
- e:pp:ik
You bet! Here are some. Restoration about to start soon. I'm looking forward to that grit being swept away. The black volume and noise are incorrect. The white and silver are the correct ones.
E:pp:ik, post the dimensions of the silver slider caps, I have many similar slider caps, in quite a few different sizes. The one black slider cap you have, is the silver indicator line made of aluminum instead of paint? If it is, it's an old Roland knob like the one on my SH-09, so I'll at least be able to make sure the caps I have will fit the slider shaft.
P.S., If that IS an old Roland slider cap, my SH-09 is missing one!
- e:pp:ik
Hi again! I was super busy through the holidays so I didn't have an opportunity to respond.
I finally measured the silver knob. 8mm W x 10mm H. White plastic interior with three slots in place.
The white knob is 17mm W x 14mm H with a set screw for D-shafts. Aluminum interior shell.
And yes ~ it's an aluminum band in the slider. Looks like a Roland to me!
E:pp:ik,E:pp:ik wrote:Hi again! I was super busy through the holidays so I didn't have an opportunity to respond.
I've gone through the pile of aluminum knobs, and I've come up empty. Everything I have is either 10mm, or 6mm or less. Very few have the proper insert, and they are all too tall. Turns out I have no white knobs anywhere close to what is needed either. Sorry. If I run across anything suitable soon (I'm going through and cleaning the workshop a bit), I'll let you know.
- e:pp:ik
Hey no problem! Like I said - it would be a near miracle if anyone had a spare.
You can take first crack at that Roland slider cap the moment I have a replacement.
Thanks anyway Teach!
