I purchased a modded x0xb0x from somebody on ebay and there's unwanted noise no matter where the parameters are set (and with both waveforms). Here's an example of what it sounds like (also added as an attachment if it works): http://www.sendspace.com/file/den59g It switches halfway through from square to saw...all mod parameters are set to 0. When the volume is at zero, I hear nothing.
I don't have the slightest clue about electronics (this is also the first piece of music gear I've ever owned)...please contact me if you can fix it or if I need to do something else so you can hear what is going on. I live in nyc and so a reference to a place that can fix it in nyc would also be much appreciated. These are the mods if it's relevant:
1./ Bass boost mod
2./ Env Mod Amount
3./ Env Mod Amount
4./ Increased Filter Low End
5./ Resonance Boost
6./ Resonance accent increase
7./ Filter Modulation (VCO)
8./ Filter Modulation (VCA)
9./ Variable VCA Decay
10./ Devilfish Filter Overdrive
Thank you very much.
FIX NOISY x0xb0x
Re: FIX NOISY x0xb0x
did you purchase this from queenie?
