Hi all. I've just ordered the rare parts from Gaetano:
1 x BA6110 Rohm OTA (9-SIP)
2 x AN6562 (8-DIP) Panasonic Dual Op-Amps
('Real' Panasonic brand AN6562's, see the rare parts list for picture.).
1 x 2SC2291 (5-SIP) Common Base Transistor.
3 x 2SC1583 (5-SIP) Common Emitter Transistors.
1 x 2SK30A(Y) TO-92 FET <- Both needed for original Sound
1 x 2SK30A(O) TO-92 FET <- Both needed for original Sound
1 x LA4140 AF Power amp (9-SIP).
24 x 2SC536F TO-92 NPN Transistors. HFE ~250 (like the original TB303).
10 x 2SA733(AP) TO-92 PNP Transistors
I'm gonna get the pcbs and panels from adafruit but I was hoping someone could suggest a reliable place to pick up the rest of the bits. Obviously since i'm from the UK, a uk based supplier would be prefferable to cut down on postage etc. Thanks in advance.
Alex.
UK parts supplier needed.
- phono
Re: UK parts supplier needed.
you should just order from gaetano, its a decent price that includes shipping plus you'll have the parts in about a week
- mr aize
You misunderstand mate. I've ordered those parts from him, what i'm looking for is a source for all the other non-rare bits. I was just hoping there was a uk supplier like the american firms mouser and digikey.
- substyler
hi mr aize
maybe check digikey UK or Farnell UK
http://dkc1.digikey.com/uk/digihome.html
http://uk.farnell.com/
Farnell also sells known good 9VAC/0.5A wallwarts
cheers
SubStyler
cheers
SubStyler
- phono
whoops my badmr aize wrote:You misunderstand mate. I've ordered those parts from him, what i'm looking for is a source for all the other non-rare bits. I was just hoping there was a uk supplier like the american firms mouser and digikey.
a nice cheap place in the uk i use is http://www.rshelectronics.co.uk
they will have all the capacitors/resistors etc, the only thing you will have problems with is the pactec case and mechanical parts (potentiometers, switchcaps, encoders) you'll most likely have to do use mouser/digikey anyway so end of the day you'll probably be better off using them for all parts you need. I had to on my self sourced x0x. It costs of course tho, shipping and import duty.
Another potential problem is the standoffs since mcmaster wont ship overseas, but you can always use metric ones and trim them a little (bit of a pain)
- mr aize
Thanks guys i'll look into them.
- mr aize
How much do they generally sting you on import/shipping btw? An did you have to trim the standoffs down? Sounds like a massive potential ass Still, was under no illusions this was gonna be easy.phono wrote: you'll most likely have to do use mouser/digikey anyway so end of the day you'll probably be better off using them for all parts you need. I had to on my self sourced x0x. It costs of course tho, shipping and import duty.
- phono
no luckily vlady had some and was kind enough to send them to memr aize wrote:How much do they generally sting you on import/shipping btw? An did you have to trim the standoffs down? Sounds like a massive potential ass Still, was under no illusions this was gonna be easy.phono wrote: you'll most likely have to do use mouser/digikey anyway so end of the day you'll probably be better off using them for all parts you need. I had to on my self sourced x0x. It costs of course tho, shipping and import duty.
erm shipping at digikey was reasonable, shipping at mouser was a sting since the pactec case is marked as "large" then since its outside the eu you need to pay vat on them (whatever the current uk vat is atm) then the post office will probably add some handling charge
its a pain, but to be honest its still worth it
I just ordered all of the resisters, capacitors, case, etc. from Mouser, postage didnt cost any extra, Im based in Ireland.mr aize wrote:How much do they generally sting you on import/shipping btw? An did you have to trim the standoffs down? Sounds like a massive potential ass Still, was under no illusions this was gonna be easy.phono wrote: you'll most likely have to do use mouser/digikey anyway so end of the day you'll probably be better off using them for all parts you need. I had to on my self sourced x0x. It costs of course tho, shipping and import duty.
**Edit: I ordered from the European Digikey site and the postage wasn't expensive at all.
- profête
hello
can you sale only one BA6110 Rohm OTA (9-SIP) please ?
or maybe you know where i can buy only one ?
thank
thank
