HAPPY LABOR DAY - ADAFRUIT IS OPEN - ALL ORDERS PLACED AFTER 11AM ET 9/4/2015 WILL NOT SHIP UNTIL TUESDAY 9/8/2015 - READ MORE!
Generate ICMP Packets
by Coniferous on Sun May 10, 2009 9:02 pm
Hello everyone!
I'm trying my best to get a network status monitor running and i've run into a road block.
How do you generate an ICMP packet using the driver_socket library? I cannot specify a source or destination port because ICMP does not use one. This puts the connect object right out.
Here is how my code looks right now... Apologies to Robert and Ada, I've totally jacked a lot of their code.
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
OBJ
  term          : "tv_text"
  settings      : "settings"
  subsys        : "subsys"
  tel           : "api_telnet_serial"
  websocket     : "api_telnet_serial"
Var
  long stack[8]
  byte status
  long statusstack[200]
Dat
        ProductName     byte    "Network Status Monitor",0
        ping1           byte    192,168,4,30
PUB start | i
  dira[0]~~                     'Set direction on reset pin
  outa[0]~                      'Set state on reset pin to LOW
  cognew(buttonwatch, @stack)   'Set a Cog to watch the reset switch
  term.start(12)                'Init the terminal
  TopBanner                     'Display The top banner thing.
  outa[0]~~ ' Pull ethernet reset pin high, ending the reset condition.
  if not \tel.start(1,2,3,4,6,7)
    showMessage(string("Unable to start networking!"))
    subsys.StatusFatalError
    SadChirp
    waitcnt(clkfreq*10000 + cnt)
    reboot
    if settings.getData(settings#NET_MAC_ADDR,@statusstack,6)
    term.str(string("MAC: "))
    repeat i from 0 to 5
      if i
        term.out("-")
      term.hex(byte[@statusstack][i],2)
    term.out(13)
  if NOT settings.getData(settings#NET_IPv4_ADDR,@statusstack,4)
    term.str(string("IPv4 ADDR: DHCP..."))
    repeat while NOT settings.getData(settings#NET_IPv4_ADDR,@statusstack,4)
      if ina[subsys#BTTNPin]
        reboot
      delay_ms(500)
  term.out($0A)
  term.out($00)
  term.str(string("IPv4 ADDR: "))
  repeat i from 0 to 3
    if i
      term.out(".")
    term.dec(byte[@statusstack][i])
  term.out(13)
  term.str(String("Pinging: "))
    if i
      term.out(".")
    term.dec(byte[@ping1][i])
  term.str(string("...  ")
  repeat
PUB buttonwatch
  repeat
      reboot
PUB Topbanner
  term.str(@ProductName)
  term.out(13)
  term.out($0c)
  term.out(2)
  repeat term#cols/2
    term.out($8E)
    term.out($88)
  term.out($0c)
  term.out(0)
PUB HappyChirp
  subsys.chirpHappy
PUB SadChirp
  subsys.chirpSad
PUB showMessage(str)
  term.str(string($1,$B,12,$C,$1))
  term.str(str)
  term.str(string($C,$8))
PRI delay_ms(Duration)
  waitcnt(((clkfreq / 1_000 * Duration - 3932)) + cnt)
Coniferous
Re: Generate ICMP Packets
by bbunk on Fri Jul 30, 2010 7:25 pm
ICMP's are broadcast packets. To generate a custom packet type, typically you will need a raw socket. Good luck!
bbunk
