I've also read the more detailed FAQ on www.deepdarc.com regarding the IR port topic.darco wrote: Q: I notice there is an IR port. What kind of remote control will I need?
A: The IR port will work with any remote control which is modulated between 38-42KHz. Most IR remotes are in this category. At the moment however, none of the widgets are really using the IR port. This will likely change in the future. An IR test feature is built into the bootloader, which will flash the LED when a button on any compatible remote is pressed.
I've tried a Sony TV remote I have as well as tried to configure a Universal Remote with the various Sony remote codes. While the ybox2 is on the bootloader screen, I see no response on the LED to any of the buttons I press on the remote control.
To help troubleshoot, can a list of the tested and confirmed remotes be shared? I'd like to figure out if it's a problem with the IR detector or a case of not using the correct remote.
