ybox2 errata
Talk about YBoxen, widgets, Propeller hacking, etc!
ybox2 errata
Postby darco » Sun Jul 20, 2008 2:33 pm
This thread is tracking errata for the ybox2. It will be updated as issues are brought to my attention.
HW v1.1 errata
* Pin 7 (write protect) on the EEPROM needs to be explicitly pulled low. This prevents spurious write problems.
...according to the datasheet this pin will be internally pulled low if left unconnected... but apparently this isn't always the case.
Adding a haywire from pin7 (the only unconnected pin on the EEPROM) to a pin on the other side of the chip (which are all connected to VSS) fixed his problems.
I would recommend everyone doing the same at some point, especially before upgrading the bootloader if you don't have a prop-plug.
* Pin 5 of the ENC28J60 should be left unconnected, instead of being connected to an I/O pin on the propeller.
* Pin 8 on the pulsejack needs to be connected to GND, not VSS.
Bootloader v1.0 errata
* DHCP doesn't seem to work with Linksys WRT54G & WRT54GS routers with stock firmware. (Still under investigation. See this post for more info.)
* Green and blue LED's are swapped.
* TCP implementation doesn't retransmit packets
* You can't remove a password without doing a full reset. (Fixed in v804)
darco
Postby balefrost » Tue Sep 23, 2008 12:10 am
I just assembled mine, and it looks like all three of the LED colors are rotated. In the www example widget, here is what I select and what I get:
Red -> Blue
Green -> Red
Blue -> Green
Yellow (red + green?) -> Purple (blue + red) (actually looks like pink, but that might just be the lighting)
I checked it against the build instructions on ladyada's site, and I think I did everything correctly.
balefrost
Postby darco » Tue Sep 23, 2008 12:25 am
This is fixed in the latest boot rom.
darco
Re: ybox2 errata
Postby bluej774 » Sat Nov 22, 2008 2:46 am
darco wrote:This thread is tracking errata for the ybox2. It will be updated as issues are brought to my attention.
HW v1.1 errata
* Pin 5 of the ENC28J60 should be left unconnected.
* DHCP doesn't seem to work with Linksys WRT54GS routers. (Still under investigation. See this post for more info.)
Has this information been updated on the soldering instructions page?
bluej774
Re: ybox2 errata
Postby Psyicman » Tue Jan 27, 2009 3:19 am
It dosent like the Linksys WRT54G v8 also.
My parents told me I could be anything I wanted to be when I grew up. I choose Ninja.
It's a rat flail!
Psyicman
Re: ybox2 errata
Postby Psyicman » Mon Feb 02, 2009 8:10 pm
How I resolved my issuse with window vista and Linksys WRT54G wireless router:
1. Hooked my ybox2 directly into my seconday ethernet slot.
2. Bridged the connection
3. Ran the DHCP server.
4. Right clicked the bridged connection went to Properties
5. Clicked Internet Protocol Version 4 (TCP/IPv4)
6. Clicked Properties
7. Clicked Use the Following IP address and filled in the one under the DHCP server (file dhcpsrv configurations setting) for the ybox2 MAC address and gatway.
8. Clicked ok and dubble checked to see if I could get the bootloader page on my web browser.
That seemed to get most of my issues. Hope this helps. Let me know if you think I left out anything.
It's a rat flail!
Psyicman
Re: ybox2 errata
Postby MajorGrubert » Thu Feb 19, 2009 3:56 pm
HW v1.1 errata
Looking at the soldering instructions page I believe the answer is not, so I would like to ask: how critical are these fixes? Since they involve adding haywires and cutting traces, I'd rather make these changes before I start assembling my newly arrived kit. Are they mandatory?
-- Major Grubert
"Stoe Orkeo!"
MajorGrubert
Re: ybox2 errata
Postby darco » Fri Feb 20, 2009 1:22 am
I have made 5 ybox2s so far, and none of them have the errata changes applied. I have had zero problems.
I would only apply the EEPROM fix if you have problems writing to the EEPROM. Since I haven't, I haven't had the need. Nonetheless, other people have had problems that were fixed by doing this. It is a fairly low-risk fix and very easy to do after the kit is built, but certainly not required in most cases.
I would only cut the trace to pin 5 of the ENC28J60 if you really need the I/O pin. The risks of cutting the wrong trace outweigh the benefits unless you really need the extra I/O pin. Despite the fact that the datasheet says to leave it unconnected, it doesn't seem to hurt anything to leave it as-is.
I hope that clarifies things.
darco
Re: ybox2 errata
Postby MajorGrubert » Fri Feb 20, 2009 12:40 pm
@darco,
it's clear now. I will apply the EEPROM fix if I try to replace the bootloader, and leave the other ones aside. Thank you.
-- Major Grubert
"Stoe Orkeo!"
MajorGrubert
Re: ybox2 errata
Postby E_Don » Sun Jun 07, 2009 11:12 pm
Psyicman wrote:How I resolved my issuse with window vista and Linksys WRT54G wireless router:
what do you mean in #2 by bridging the connection? im new to this =(
E_Don
Re: ybox2 errata
Postby samirsky » Fri Jun 26, 2009 10:29 pm
Psyicman wrote:It dosent like the Linksys WRT54G v8 also.
It doesn't like my 3COM router (3CRWE51196). Doesn't get IP address. Took Ybox2 to work and it got IP address. Upgraded bootloader, no change.
samirsky
Re: ybox2 errata
Postby darco » Sun Jun 28, 2009 2:43 am
I'm not sure what is wrong. All of my routers work. I can't fix what I can't see. :(
darco
Return to YBox2
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
