Hi all,
I just wanted to show some progress on my latest home project. I'm playing with ZigBee nodes (802.15.4) one of which I attached to the headers on the YBox2 (pic's attached).
I'm using the XBee boards (2mW sufficient for my use). I get them from here: http://www.sparkfun.com/commerce/produc ... ts_id=8691
I have the new XBeeMonWidget successfully communicating with the XBee daughter board and also successfully scanning for any nodes found (via RF 2.4GHz Zigbee). The node scan is a separate page served from the web-server in YBox2.
I'll attach more notes as I progress through my project. If anybody else is playing with this mix (Zigbee + YBox2) please comment!
[See attached the pics]
Regards,
Stephen, KZ0Q
http://kz0q.us
Lurking on Zigbee net with YBox2 logging and showing status
- Attachments
- Here's the web served home page
Notice I didn't modify the settings form, yet... (have to decide what settings are useful, first ;-) - XBeeMonWidgetHome.JPG (57.14 KiB) Viewed 4692 times
- And from another angle
- HPIM1356crop.jpg (105.26 KiB) Viewed 4689 times
- The XBee board mounted on YBox2
- HPIM1355crop.jpg (65.43 KiB) Viewed 4690 times
Re: Lurking on Zigbee net with YBox2 logging and showing status
Since I can only attach three pics.. here's the Node Discovery page prototype
-Stephen, KX0Q
-Stephen, KX0Q
- Attachments
- Here's a slightly larger page but showing the NODEs seen via the radio
- XBeeMonWidgetNodeList.JPG (126.52 KiB) Viewed 4698 times
Here's the Connector pin-out worksheet I used.
I'm only connecting VCC, GND, DIN, DOUT and RESETb and RSSI (but ignoring this) for
now...
The XBee adapter board is straddling the U$3 and JP2 connectors. It only gets VDD from U$3.
All the remaining signals route to JP2.
Stephen, KZ0Q
now...
Stephen, KZ0Q
- Attachments
- My pinout worksheet...
- XBeeConnectorSetup.jpg (55.99 KiB) Viewed 4674 times
ive been playing with xbees lately myself
so, er...whats it for?
ladyada, I've been toying with the idea of a home control/sensor net based on a small
flock of sensors and temperature (thermostat) control. The page you don't see, as I've
not created it yet, is the current reported values for all the sensors in the net. I'm
starting small with three or four. Am still looking for something less than $18 per
temperature/humidity sensor. Seems hard to come by. Also trying to solve the
"line voltage thermostat" control problem. Seems no one has hacked either the
"TL8230A Honeywell LineVoltPRO Digital Programmable Thermostat" or the
"Oregon Scientific THGR122NX Wireless Temp/Humidity Sensor" which both look
like they may be a starting point... The sensor I'm a fan of (but it's $18ish) is
the sensirion sht1x/sht7x precision humidity and temperature sensor.
The challenge I'm facing is an older, all electric, house at 7300 ft elevation
(always cooler). No central anything, each room has own heaters and controls.
Would like to see how it's performing and reign in the expenses... thought it
might be fun project. I seem to have a lot to learn...
(which just emphasizes the fun
Any / all constructive advice welcome!
How about yourself, what brings you to XBee?
Regards,
Stephen, KZ0Q
Regards,
Stephen, KZ0Q
- irritantno9
Pretty cool!
How about a shot of the Video side of this project.
Any link to schematics and source?
@irritant#9, I'll post schematic and code shortly.... I've just started this as you can see.
Regarding the code, I'm using the XBee object from the Parallax Object Exchange. This made
the YBox2 implementation very simple.
Meanwhile, while I'm figuring out what sensors to use... I'm moving to prototype what the
sensors would say via the radios. For the sensor side I'm writing an application in C# which
will drive the XBee device via USB using the Explorer board from SparkFun
[See: http://www.sparkfun.com/commerce/produc ... ts_id=8687]
At this point i'm rereading the XBee docs regarding messaging (broadcast, point-to-point, and
end-point selection, etc.) and determine which form(s) look most likely to use. An issue is
what do we want to be able to see at the YBox2 as the sensors are reporting. Also, should the
YBox2 be forwarding the data to a central logging and reporting machine or should this central
machine also be monitoring the sensor net and logging all traffic reported and generating the
more detailed (longer timeframe) reports? The YBox2 can then simply provide the links for
accessing them from the central machine requiring much less storage... Hmmm... much
to think about!
See the attached pics.
Happy New Year all!
-Stephen ,KZ0Q
to think about!
Happy New Year all!
-Stephen ,KZ0Q
- Attachments
- Here's one of the XBee devices connected via USB.
- HPIM0506resize.jpg (121.66 KiB) Viewed 4604 times
- This is the top window of the C# app which is pretending to be a sensor node...
- XBeeSensorMockup.PNG (16.62 KiB) Viewed 4601 times
im upgrading my 'kill-a-watt' power monitors with xbees
Hey stephmo do you have any screenshots of the TV? Whats the YBox2 displaying afterall?
