problem compiling RTClib
Postby Mark Snaterse » Mon May 14, 2012 4:28 pm
I am having a problem compiling RTClib. I am using Arduino 1.0, and have downloaded the latest version of the library (from https://github.com/adafruit/RTClib). Below is the error I am getting. Any pointers in the right direction would be appreciated!
In file included from sketch_may14a.cpp:1:
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:7: error: expected `)' before 't'
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:8: error: expected `)' before 'year'
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:11: error: 'uint16_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:12: error: 'uint8_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:13: error: 'uint8_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:14: error: 'uint8_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:15: error: 'uint8_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:16: error: 'uint8_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:17: error: 'uint8_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:22: error: 'uint32_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:25: error: 'uint8_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:31: error: 'uint8_t' does not name a type
C:\Documents and Settings\~\My Documents\Arduino\libraries\RTClib/RTClib.h:33: error: 'uint8_t' does not name a type
Mark Snaterse
Re: problem compiling RTClib
Postby adafruit_support_rick » Mon May 14, 2012 4:47 pm
You seem to missing a header file. Check that you have all the necessary #include statements at the top of your sketch.
Postby pburgess » Mon May 14, 2012 4:51 pm
Hi Mark,
Is this with the ds1307 example sketch included with the library, or in your own code?
If your own code, make sure you're also including this file at the top of your sketch:
#include <Wire.h>
pburgess
Postby Mark Snaterse » Mon May 14, 2012 5:02 pm
Mark Snaterse
Postby platezero » Tue Jun 26, 2012 4:41 pm
Thank you very much pburgess.
solved by include command
#include <Wire.h>
it's Work! :wink:
platezero
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 11 guests
New Products [102]
LEDs[109]
Cables[60]
