MicroSD card breakout board & Arduino Pro Mini 3.3V 8 MHz
by buton on Fri May 25, 2012 9:13 am
i had problems reading the breakout board from the Arduino pro mini...
how ever it works with an arduino UNO..
is the breakout board compatible with the MINI?
buton
Re: MicroSD card breakout board & Arduino Pro Mini 3.3V 8 MHz
by adafruit_support_bill on Fri May 25, 2012 9:42 am
It is compatible with 3.3v logic. We have not tested it specifically with the Pro Mini.
by buton on Fri May 25, 2012 10:32 am
Maybe it could be a timing issue because of the 8 mhz clock?
buton
by adafruit_support_bill on Fri May 25, 2012 10:51 am
I have heard of issues with accessing SD cards on 8MHz variants. We don't carry any of them, so I don't have any firsthand experience with it.
by buton on Fri May 25, 2012 11:06 am
if i power the breakout module with external 5 volt.. the arduino pro mini will read and recognize the SD card...
buton
by adafruit_support_bill on Fri May 25, 2012 11:12 am
Yes. The on-board 3.3v regulator needs >3.3v to properly regulate.
by buton on Fri Jun 01, 2012 10:44 am
i got it to work...
buton
