Using a salvaged printer stepper motor
Postby rweber95 » Sun Jun 10, 2012 12:28 am
I just finished assembling my Motor Shield and needed a stepper motor to test it out with. I have several printer motors that I've salvaged over the years, one of which is an OKI QH4-4487 rated at 24.2 V, 8.8 ohms. This requires 24.2/8.8=2.75 amps, way more than the L293D can handle. I have an old wall wart Motorola Cell phone unregulated charger rated 4.5-9.5 VDC, 800 ma. It's open circuit voltage read 5.25 VDC which at 8.8 ohms will draw 570 ma max.
I ran adafruit stepper test at single, double, interlace and micostep commands while measuring the average voltage and current drawn at the boards external voltage connector.
Single, 4.16V, 280 ma,
Double, 3.37V, 385 ma,
Interlace, 3.75V, 340 ma,
Microstep, 4.45V, 220 ma.
rweber95
Re: Using a salvaged printer stepper motor
Postby adafruit_support_bill » Sun Jun 10, 2012 5:13 am
Sounds good! There are a lot of old printer motors out there. Many will run fine on less than rated voltage. Obviously the torque will be lower, but if it is enough for your purposes, these are great motors for hacking. :D
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 11 guests
New Products [103]
LEDs[109]
Cables[61]
