I recently soldered the shield together and went to use it and no-go. Besides building things I also want to learn how to troubleshoot when it doesn't work. Having access to an oscilloscope I was checking different components and I am assuming that the issue may be near the op amp.
Here's what I did:
1. downloaded example wave files and when I compile and check serial monitor it seems to be playing ok. So it should be reading sd card ok.
2. check the DAC and it's putting out the voltage.
3. Here's where I need help. I connected the probe to the input of the amp and as I adjust the potentiometer the levels adjust from 2 - 7 mV. On the output side I am not getting anything. This is why I assume the issue may be here.
Would like to know where else to check because I would like to learn how to fix this because this is a good learning experience.
