I’m a bit confused by this new shield – the updated documentation states:
“The latest revision of the shield adds a micro-SD card slot, which can be used to store files for serving over the network.”
Then it also states:
“Note that because the W5100 and SD card share the SPI bus, only one can be active at a time.”
Is it really possible to pull files from the SD card over the Ethernet? If so could a client/broswer pull a file using the following format: http://10.10.10.1/file-to-snag.txt?
Nate
Arduino Ethernet shield with SD card - File hosting?
- nate strech
Re: Arduino Ethernet shield with SD card - File hosting?
the description is technically confusing but basically what it means is - you have to interleave SD card access and ethernet access. it just means its not super fast, not that you can't essentially do both at the same time
note that there is no precise example code to do what you want (yet)
I just got this card and trying to figure out what the preferred lib is to use for SD IO, I came across this one ...
http://code.google.com/p/sdfatlib/
But after running a few tests they seem to bail out ...
Free RAM: 1261
error: card.init failed!
SD error: 1,0
Is this something more specific to be using?
Thanks.
Free RAM: 1261
SD error: 1,0
Thanks.
- nate strech
Hi jonbaer,
I had the same issue but I just figured it out…
BACKGROUND:
SPI is a protocol designed for communicating between two devices. You can read more about it on Wikipedia; but for our purposes it's important to know that there are four signals used in SPI: MOSI, MISO, SCK and CS (or SS). These signals are defined in a FAT library and associated with a specific pin. On Arduino, the default pins are D10 (CS), D11, (MOSI), D12 (MISO) and D13 (SCK).
(source: http://www.sparkfun.com/commerce/tutori ... als_id=172)
So a basic Ethernet Shield will use the SS pin 10 to select the Wiznet W5100 Ethernet chip. It also looks like most Data Logging shields also use the same SS pin 10 to access the SC card.
RESOLUTION:
Seeing that this new shield has both - pin 10 is for the W5100 and pin 4 is for the SD card. You’ll have to make a small code change in the SDFATLIB.
I’m currently using this version: sdfatlib20100818
Open the file called ‘Sd2PinMap.h’ and drop down to line 279. Change the SS_PIN value to 4.
Now that my SD card is working I’ll still have to see if will play nicely with the Ethernet chip.
This looks promising… http://www.webweavertech.com/ovidiu/web ... 00476.html
Cheers,
Nate
BACKGROUND:
RESOLUTION:
#else // defined(__AVR_ATmega1280__)
// 168 and 328 Arduinos
// Two Wire (aka I2C) ports
uint8_t const SDA_PIN = 18;
uint8_t const SCL_PIN = 19;
// SPI port
// uint8_t const SS_PIN = 10;
uint8_t const SS_PIN = 4 ; //THIS LINE
uint8_t const MOSI_PIN = 11;
uint8_t const MISO_PIN = 12;
uint8_t const SCK_PIN = 13;
Cheers,
Nate
- fat16lib
To change the chip select pin for the SD please do not edit Sd2PinMap.h. This may cause problems since it changes both the value of SS and SD chip select. These are different pins on the Ethernet Shield.
The SparkFun documentation is not correct for the current version of SdFat. SS, pin 10, will be set as an output independent of the pin used for SD chip select.
Either use init with two arguments
For the ethernet SD the call would be something like
You can also edit Sd2Card.h at line 60 and change the default SD chip select.
Original:
New default pin 4:
uint8_t Sd2Card:init(uint8_t sckRateID, uint8_t chipSelectPin);
card.init(SPI_FULL_SPEED, 4)
Original:
uint8_t const SD_CHIP_SELECT_PIN = SS_PIN;
uint8_t const SD_CHIP_SELECT_PIN = 4;
We have a full tutorial here
http://www.ladyada.net/learn/arduino/ethfiles.html
make sure to delete your old version of SDfatlib completely before reinstalling!!
- nate strech
Fat16lib & Adafruit – Excellent information!
I could have really used this new tutorial three days ago
You’ve answered my original question about hosting files in the format of: http://10.10.10.1/file-to-snag.txt
I went about it a slightly different way and managed to complete my Cisco IP Phone project: http://www.youtube.com/watch?v=LnTGZVIdx38
Thanks for staying on top of this forum – I wouldn’t get very far without it!
ahhh...we only wrote it 12 hours ago - in response to your posts
- Andyx
Good job on the tutorial.
Here is a version of the web server sketch turning it into a little more or less of a server.
It adds support for a root file name and jpeg and gif image content types to the server.
It also corrects a minor problem in the SD byte reading loop that affected image content types.
* Web Server
* A simple web server that shows the value of the analog input pins.
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 177 };
char rootFileName[] = "index.htm";
Server server(80);
/************ SDCARD STUFF ************/
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
Serial.begin(9600);
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
digitalWrite(10, HIGH); // but turn off the W5100 chip!
if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
// initialize a FAT volume
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(),DEC);
Serial.println();
if (!root.openRoot(&volume)) error("openRoot failed");
// list file in root with date and size
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
Serial.println();
// Recursive list of all directories
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
Serial.println();
PgmPrintln("Done");
// Debugging complete, we start the server!
Ethernet.begin(mac, ip);
server.begin();
// How big our line buffer should be. 100 is plenty!
#define BUFSIZ 100
void loop()
char clientline[BUFSIZ];
char *filename;
int index = 0;
int image = 0;
Client client = server.available();
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
// reset the input buffer
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// If it isn't a new line, add the character to the buffer
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
// are we too big for the buffer? start tossing out data
if (index >= BUFSIZ)
index = BUFSIZ -1;
// continue to read more data!
continue;
// got a \n or \r new line, which means the string is done
clientline[index] = 0;
filename = 0;
// Print it out for debugging
Serial.println(clientline);
// Look for substring such as a request to get the root file
if (strstr(clientline, "GET / ") != 0) {
filename = rootFileName;
if (strstr(clientline, "GET /") != 0) {
// this time no space after the /, so a sub-file
if (!filename) filename = clientline + 5; // look after the "GET /" (5 chars)
// a little trick, look for the " HTTP/1.1" string and
// turn the first character of the substring into a 0 to clear it out.
(strstr(clientline, " HTTP"))[0] = 0;
// print the file we want
Serial.println(filename);
if (! file.open(&root, filename, O_READ)) {
client.println("HTTP/1.1 404 Not Found");
client.println("Content-Type: text/html");
client.println();
client.println("<h2>File Not Found!</h2>");
break;
Serial.println("Opened!");
client.println("HTTP/1.1 200 OK");
if (strstr(filename, ".htm") != 0)
else if (strstr(filename, ".jpg") != 0)
client.println("Content-Type: image/jpeg");
else if (strstr(filename, ".gif") != 0)
client.println("Content-Type: image/gif");
else
client.println("Content-Type: text");
client.println();
int16_t c;
while ((c = file.read()) >= 0) {
// uncomment the serial to debug (slow!)
//Serial.print((char)c);
client.print((char)c);
file.close();
} else {
// everything else is a 404
client.println();
break;
// give the web browser time to receive the data
delay(1);
client.stop();
nice! are you by chance on github?
- Andyx
Added github link to my profile.
if youd like, you can fork our code and mod it
we'll post it on our tutorial
- Andyx
