Usable Arduino pins for Motor Shield Projects
Re: Usable Arduino pins for Motor Shield Projects
by Rocobics on Sun Mar 13, 2011 7:33 pm
Hello.
I am also new, and I have a question.
How do I use the available pins? I'm guessing I don't solder the headers in the pins I want to use?
Also, what does broken out mean in here:
The analog pins (analog 0-5 also known as digital pins 14-19) are broken out in the bottom right corner.
Rocobics
by adafruit_support_bill on Mon Mar 14, 2011 5:52 am
One way to use the available pins is to build the shield with stackiing headers.
There are holes with solder-pads for all of the analog pins in one corner of the board.
These are arranged next to power and ground pads to make it easy to attach 3-pin sensors.
by Rocobics on Wed Mar 16, 2011 2:26 pm
Thanks for your response. So you just solder in those instead of the male header pins.
Do you know of what local stores (US) sell these stacking headers (I'm assuming I have to pay for shipping on those headers you linked to?)?
EDIT: What other alternative ways are there to use the available pins without headers? (if any)
Thanks again. :)
Rocobics
by adafruit_support_bill on Wed Mar 16, 2011 4:18 pm
Those may be hard to source locally - unless you are lucky enough to live near a big supplier. I doubt that Radio Shack would carry them.
The alternative is to solder to the tops of the male header strips.
by jonedwrd on Wed Mar 23, 2011 4:11 am
Digital pins 9 and 10 are used by the motorshield to control the servo pins, right? I'm using the motorshield to control two steppers and no servos, but need access to digital 9,10...can I access them at the servo pins of the motor shield?
jonedwrd
by adafruit_support_bill on Wed Mar 23, 2011 6:07 am
Yes. Pins 9 & 10 are available on the innermost pins of the servo headers.
