Speaker - 3" diameter (77mm), 8 ohm impedence, good response between 200Hz to 10KHz (10KHz is the max frequency the Wave shield can make). The speaker is rated for 1W so if you want you can even stick a small amp between the shield and the speaker to boost up the volume
Also, I've never built an amplifier.
What is the easiset way to boost the sound volume (I've already boosted my sound file as loud as it can go without distorion)?
Cheers
