Sanguino and WaveShield
by anxion on Tue Apr 13, 2010 11:57 am
Did you know if the WaveShield is fully compatible with the Sanguino mapping ?
I need the Sanguino because my 328P haven't enough ram to launch my program and the WaveHC in the same time.
FreeRam test said -650 bytes :shock: ..
anxion
Re: Sanguino and WaveShield
by adafruit on Tue Apr 13, 2010 1:14 pm
someone may have 'ported' it to the sanguino but otherwise, no we have not done it ourselves
by fat16lib on Tue Apr 13, 2010 4:04 pm
The pin mapping is not defined for the Sanguino in WaveHC.
ArduinoPins.h checks for a Sanguino but only generates an error since the pins are not defined.
You could define a pin map and try the Wave Shield on the Sanguino. The SPI pins for the Sanguino are :
# Digital 4 - SS (used for SPI)
# Digital 5 - MOSI (used for SPI)
# Digital 6 - MISO (used for SPI)
# DIgital 7 - SCK (used for SPI)
You need to define three or four pins for the DAC. You only need three if you ground LAT.
fat16lib
by anxion on Tue May 04, 2010 10:02 am
Ok thanks, I've received my Sanguino this morning, I'm gonna try this and give you a report.
http://www.atmel.com/dyn/resources/prod ... /8011S.pdf
The SPI pins aren't 4, 5, 6, 7 instead of 5 ,6, 7, 8 ?
anxion
by fat16lib on Tue May 04, 2010 6:45 pm
The Sanguino spi pins should be 4, 5, 6, 7. I corrected the above error.
fat16lib
by anxion on Wed May 05, 2010 12:08 pm
I've modified ArduinoPins.h and WavePinDefs.h
The WaveShield works great on both board :D
If we are running on ATmega128, 328, 1280 it use Arduino pins 2, 3, 4, 5 for DAC and if it's ATmega644P it use Sanguino pins 0, 1, 2, 3
WavePinDefs.h
Sanguino support added
(3.17 KiB) Downloaded 131 times
ArduinoPins.h
(14.24 KiB) Downloaded 180 times
anxion
by fat16lib on Thu May 06, 2010 11:02 am
Thank you. I will include your Sanguino mods in a future release of WaveHC.
fat16lib
by Bratan on Sat Dec 01, 2012 12:21 pm
Wow, works like a charm! :) Thank you so much anxion!
fat15lib, Please include it the future library :)
Bratan
