I'm a beginner in Arduino and electronic.
I'm using the motorshield for my little rover. It work well alone. Then if use it with RF315mhz and virtualWire, it work fine too, i can transmit order to turn left, right, backward, forward... But if I include servoTimer2.h (servo.h can't be use with virtualWire.h cause they both use timer1) motor 2 doesn't run anymore. Motor 3 and 4 work but not 2. Servo is on the pin 9.
Do you know what is the problem ? why only motor 2 doesn't works ?
Thx,
MadProf
PS: sry for my english
MotorShiel + virtualWire + servoTimer2
Re: MotorShiel + virtualWire + servoTimer2
I'm not familiar with ServoTimer2, but I would suspect there is a timer conflict between that and the AFMotor library. AFMotor uses timers for the PWM. It uses a different timer for motors 1&2 vs. 3&4.
Thx for your reply arduwino,
It confirm what I thought, but I absolutely don't know how to use AFMotor + virtualWire + a servo's library. Is it possible to change the timer for the lib servoTimer2 ? Is there a third timer ?
ServoTimer2 thread
I'm sorry if I ask dumb questions...
MadProf
ServoTimer2 thread
MadProf
There are only three hardware timers on the Duemilanove. It would probably take some tricky coding to get all three libraries to work together.
The Mega has 4 timers. You might have better luck with that.
Thx for your response.
Do you think the 3rd timer is in use or I can use it without facing problems ?
I have 2 arduino, some shields, so I don't want to buy an other board.
It looks like the servoTimer2 and the VirtualWire each use one timer. AFMotor uses two.
From the source code, AFMotor is using timer0 and timer2. You said that VirtualWire is using timer1. I would guess that servoTimer2 is also using timer2. It might be possible to hack two of the libraries to share a timer, but that is not likely to be a trivial task.
Other possibilities:
If you don't need bidirectional control on all of your motors, you could use a simple transister controller for one of them.
You could use a serial motor controller like one of the ones from Pololu. http://www.pololu.com/
Unfortunately I need bidirectional for both motors...
I will look for a arduino mega if it's the only solution. I'm not capable of hack the library.
Thx for your help.
MadProf
Thx for your help.
MadProf
