Hi
I have the following shields(datalogger and Xbee)
http://www.ladyada.net/make/logshield/
http://www.sparkfun.com/products/8471
Can i stack one on top of the other(pin-conflicts)? I plan to put female headers on the Datalogger shield
Will the 2 shields draw too much power and fry something?
I am planning to stack the shields in the following order
Arduino->Data Logger->Xbee
Pls help as i need to get this going urgently and have been looking at the xbee datasheets without much luck.
Sam
Combining the data-logger shield, and the x-bee shield
Re: Combining the data-logger shield, and the x-bee shield
Check this handy site for pin usage information on shields: http://shieldlist.org/
Thanks so much
That's an awesome site.
Luckily the Datalogger shield and the Xbee shield don't use the same set of pins.
Can both shields draw power from a single Arduino board?
Is there a way to power the Datalogger shield independently?
Regds
Sam
Regds
Sam
You should be able to power both from an Arduino.
Hi
I got the datalogger shield to start logging data, but for some reason the led's don't glow.
I am using
#define redLEDpin 3
#define greenLEDpin 4, in the code. Is this correct?
Could i have damaged the LED's with clumsy soldering?
I don't understand why LOG_INTERVAL and SYNC_INTERVAL should be different?
Don't we want to sync as soon as often as we log? Wouldn't we drop data otherwise?
Sam
I am using
#define redLEDpin 3
Sam
The LEDs are multi-purpose. You need to install jumpers to make them work. In the photo below, they are jumpered to pins 2 and 3.
Thanks, for that.
What about LOG_Interval and SYNC_interval.
How can they be different?
I use 20ms for LOG and 50ms for Sync. Does this make sense? What if i chose 50000ms for sync? Where would it buffer all the data in-between?
Sam
Sam
The issue is addressed in the tutorial: http://www.ladyada.net/make/logshield/l ... kthru.html
A sync required writing a whole 2048 byte block of data, even if you only added a few bytes to the file. This is time consuming. It also consumes power which is a major concern in battery-powered logging applications. Flash memory in general has a limited number of write/erase cycles (about 10,000) per block also.
The ultimate fail-safe system would sync on every write, but you should trade this off against logging volume, timeliness, flash lifetime and power considerations.
