Adafruit Light-and-Temp-logger with file timestamps
by fat16lib on Mon Dec 12, 2011 2:41 pm
Here is a modified version of the Data Logging Shield example, lighttemplogger.pde, that will set the file creation date and time on logfiles.
lighttemplogger.zip
(2.38 KiB) Downloaded 223 times
fat16lib
Re: Adafruit Light-and-Temp-logger with file timestamps
by adafruit on Mon Dec 12, 2011 4:02 pm
neat thanks!
by cra451 on Mon May 14, 2012 2:35 am
Perfect Thanks.... Works like a charm.
cra451
by Mild Lee Interested on Fri Feb 08, 2013 8:37 am
Hmmm,
When I use this code example, each log file still resets to 1/1/2000 1:00AM
I am using the example exactly "as is" in Arduino22.
Is it possible to easily explain where the code resets the RTC?
Mild Lee Interested
by adafruit_support_bill on Fri Feb 08, 2013 9:45 am
That code does not reset the RTC. It connects to it here:
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
    error("RTC failed");
If you do not see the "RTC failed" then it has successfully connected. If your RTC is not running, it will be stuck at the default time 1/1/2000 1:00AM, you need to run one of the examples from the RTCLib to initialize it and adjust it to your computer time.
