RFID Charlie Bear Project Software Snag from MAKEvol28
jonathanray17
Post by jonathanray17 »
First of all, a sleepy good morning from my garage where I yet again have returned to do battle with this infernal project. If you're unfamiliar with the project listed in the subject, http://makeprojects.com/Project/Charlie ... Bear/1411/, meet my nemesis. Currently he has taken the form of an oversized black lab retriever with stuffing pouring out of his poorly unstitched sides and has a messy necklace of dangling wires, boards, and speakers. However, as far as I can tell, the problem I'm facing is not hardware (and yes, I bought everything on that parts list directly from MakerShed and Jameco- no dodgy 3rd party stuff)...
Last night I successfully got sound in the form of the "daphc.pde" sketch. My RFID reader prints the tags magnificently. However, trying to unite sound and RFID seem to be a bit beyond my grasp. Below is the code for "bear:"
// An interactive bear for Charlie -- RFID triggered sound responses
#include <FatReader.h>
#include <SdReader.h>
#include "WaveHC.h"
#include "WaveUtil.h"
SdReader memcard;
FatVolume vol;
FatReader root;
FatReader file;
WaveHC wave;
#define ENABLE 7      // Set the pin number for enabling the RFID reader. The Audio Shield uses pins 2-5.
#define NUMTAGS 22
int  val = 0;
char code[10];
int bytesread = 0;
char knowntags[NUMTAGS][11] = {"2100DFB002", "2100E0B6ED", "2100DFF660", "2100DFD586", "2100DFB1E5", "2100E0CBAA", "2100E07B21", "2100E0B9D6", "2100D82331", "2100DFA060", "2100DFBC77", "2100DFA69A", "2100D7EFF7", "2100DFE251", "2100E02F09", "2100DFBF83", "2100DFD9EA", "2100E0ABA6", "2100DFDFC4", "2100DFF0DF", "36005B7B50", "36005B7C05"};
char soundfiles[NUMTAGS][9] = {"1000.WAV", "1001.WAV", "1002.WAV", "1003.WAV", "1004.WAV", "1005.WAV", "1006.WAV", "1007.WAV", "1008.WAV", "1009.WAV", "1010.WAV", "1011.WAV", "1012.WAV", "1013.WAV", "1014.WAV", "1015.WAV", "1016.WAV", "1017.WAV", "1018.WAV", "1019.WAV", "1020.WAV", "1021.WAV"};
char filename[1][13];
  //////// Set up RFID reader to collect tag information /////////////////////
  Serial.begin(2400);         // RFID reader SOUT pin connected to Serial RX pin at 2400bps
  pinMode(ENABLE,OUTPUT);     // Set digital pin 7 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(ENABLE, LOW);  // Activate the RFID reader
  //////// Set the pins to output for driving the Audio Shield
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  ////////// Set up the Audio Shield by initializing the memory card for reading ////////
  if (!memcard.init()) {
    // If something went wrong sdErrorCheck prints out the error check
    putstring_nl("Card init. failed!");
    cardErrorCheck();
    return;
  //This will optimize the reading of the memory card -- remove it if it times out
  memcard.partialBlockRead(true);
  // Find a FAT formatted partition by looking in teh first five slots. Remember your memory card should be FAT16 or FAT32 formatted
  uint8_t partition;
  for (partition = 0; partition < 5; partition++) {
    if (vol.init(memcard, partition))
      break;
  if (partition == 5)
    putstring_nl("No valid FAT partition");
    cardErrorCheck();
    while(1); // This is a point of no return. Format your memory card properly and try again.
  // Open the root directory for reading the files
  if (!root.openRoot(vol))
    putstring_nl("Can't open root directory");
    while(1); // Something went wrong here so investigate the file system on your memory card.
  // If you got this far then the card is ready to read
  putstring_nl("Ready to go");
// If we find an error, check what the error is and show it on the serial terminal
void cardErrorCheck(void)
  if(!memcard.errorCode()) return;
  putstring("\n\rSD I/O error:");
  Serial.print(memcard.errorCode());
  putstring(", ");
  Serial.print(memcard.errorData());
  while(1); // Stick here if there is an error
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        playsound(code);
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
        Serial.flush();                  // Flush the serial buffer before trying to read a new code
      bytesread = 0;
void playsound(char codetoplay[]) {
  for(int i = 0; i<8; i++) {    // Make a filename from the first 8 characters of the RFID tag number
    filename[0][i]=codetoplay[i];
  filename[0][8]='.';
  filename[0][9]='w';
  filename[0][10]='a';
  filename[0][11]='v';
  silence(); //shut down anything that is currently playing and close that file
  playfile(filename[0]);
void playfile(char *name) {
  if (!file.open(root, name)) {
      putstring_nl("Couldn't open file");
      return;
   if (!wave.create(file)) {
     putstring_nl("Not a valid WAV");
     return;
  wave.play();
void silence() {
  if(wave.isplaying) {
    wave.stop();
So what does Serial Monitor say when I put a RFID tag near the reader?
€Ready to go
Couldn't open file
TAG code is: 3D001ED8B7
Near as I can tell, that means that I'm facing a software issue of not being able to summon the right file name. My .wav file is properly encoded/ect for the waveshield and named "3D001ED8.wav", as demanded by the project code. I'm kind of lost at this point and need all the help getting this infernal christmas gift done by tomorrow!
Thanks in advance for your help!
Re: RFID Charlie Bear Project Software Snag from MAKEvol28
Are those "oh's" or "zeros"?
jonathanray17
They are both zero. (On the Serial Monitor, they have a line through them, indicative of zero.)
Try changing the ".wav" to ".WAV"?
jonathanray17
Just tried .WAV, but changing it made no difference. :(
Check the output of daphc. It should print out the named of the files exactly as read from the card. Make sure that your file name matches exactly. Also - this sketch expects the file to be found at the root level. Make sure you don't have it in a nested folder.
jonathanray17
This is what I get back from daphc:
The sound file is at root level.
What is "Wbdir: 502"?
You also have a lot of garbage in the output. If I recall, the Charlie Bear project has other connections to the serial pins that might be messing that up.
jonathanray17
To be honest, I have no earthly clue. I just ran the sketch I found under Files>>Sketchbook>>libraries>>WaveHC>>daphc and opened up the serial monitor.
As for the garbage, what can I do about that?
Looking at the code, 'Wbdir: 502" looks like slightly corrupted output from these statements:
    if (file.isDir()) {                    // check if we opened a new directory
      putstring("Subdir: ");
      printName(dirBuf);
      dirLevel += 2;                       // add more spaces
      // play files in subdirectory
      play(file);                         // recursive!
      dirLevel -= 2;
which would tend to indicate that your file is not at the root level.
Try disconnecting any wires from pins 0 and 1.
jonathanray17
This is in only file and it's on the root.
As far as pins 0 and 1, there was a wire (goes from pin 0 to RFID scanner). However, after I removed it, I tried daphc again and I'm still getting garbage in the serial monitor.
Meanwhile the "bear" is singing out that .wav file on loop. (It's supposed to read it twice normally, twice frighteningly slow, and then repeat, right?)
Could be that '502' is an empty root-level folder and the wav file is at root level too. Macs create some 'invisible' files and folders that can confuse a simple file system as used by WaveHC.
Not sure what else would be causing the junk in the serial output. You can double-check that the baud-rate in your serial monitor matches what you have in the code. But if that were the problem, I wouldn't expect any of the output to be readable.
Not sure about the Charlie Bear sketch, but dapHC just plays it in a loop.
jonathanray17
Right- I can't get a sound out of the waveshield when I run the CharlieBear sketch but it won't shut up while running dapHC.
Near as I can tell, my primary issue here is confusion in the CharlieBear sketch where there's a software disconnect between reading the RFID tag, truncating the first 8 characters, and summoning the corresponding .wav file. :?
You could try printing out the file name in the 'playfile' function of the sketch (as in the snippet below) & verify that it is exactly the same as the file name on disk. You could also look at the contents of the card on a windows machine and delete everything but your .wav files.
      putstring_nl(name);
          return;
         return;
      wave.play();
sdfine
Post by sdfine »
I completed the build. This is my first Arduino project and the first circuit board I ever soldered but the build was successful. The only issue I had were software issues. The serial port speed (throuigh the Arduino software) had to be lowered in order to read the RFID feed. The Arduino sketch is not compatible with the current version of the Arduino environment. I had to load an older version in order for it to run. The Wave Shield required sketch libraries to be installed from http://code.google.com/p/wavehc/downloads/list also.
