actually, if you look closer at my playComplete, I have removed the while(1){} in order for it to be able to check for other buttons.
so this could actually be the problem? that the arduino is doing other stuff while playing?? wow this is getting interesting
Wave Shield Distortion
- soerena
Re: Wave Shield Distortion
i just tried putting back the while(1), and now there's no distortion!! wauw!
So I need to find some kind of work-around, for it to listen for other buttons without distorting while playing.. any ideas?
The playback is interrupt-driven, so normal program execution should not affect it. However, it is possible that the i2c communication disables interrupts long enough to disrupt the timing.
- soerena
OK, so it seems to be the I2C read that I'm doing that causes the distortion. A few delays for debouncing doesn't affect the sound.
Delays should be fine. The delay function does not disable interrupts.
- soerena
So reading an I2C device disables interrupts, but writing doesn't?
Because I'm writing without any audible issues, but as soon as I start reading there's distortion.
Writing does not need to use interrupts. The writer is in control of the bus and does not need to respond to asynchronously received data.
- soerena
Thanks Bill! That cleared up some stuff.
So now that I can't use the I2C for reading, I guess I'll have to make a resistor ladder on my device nr 2 as well since I only have 11 available IO's on the board.
Are there any work-arounds, alternatives or is this really what I have to do? If so, then I'm in a hell of a hurry to rearrange my circuit and everything.
Options I can see are:
- A resistor ladder as you suggested.
Wire your buttons in a matrix like a keypad: http://playground.arduino.cc/Main/KeypadTutorial
Some combination of the above.
