Motor Shield Stepper Issue
Postby snaggletooth » Wed Feb 15, 2012 1:11 am
Hello again,
I have a 2000mA 5V supply connected to EXT PWR and an Arduino Mega 2560 trying to run a stepper motor that requires 2.5 A to drive. I have piggybacked L293DNEs but the motor is not driving a load, leading me to believe that the current supplied directly to the motor is still not enough. My question is a) am I measuring the current right by putting an ammeter in series between a coil of the motor and a slot of M1, and then repeating for the rest of the coils in M1 and M2? If so I am only seeing ~1 mA/coil which is drastically under what I expected.
snaggletooth
Re: Motor Shield Stepper Issue
Postby adafruit_support_bill » Wed Feb 15, 2012 6:03 am
The L293D is rated at 600mA. 2 stacked L293D's will get you to about 1A. They are probably going into thermal shutdown with a 2.5A motor.
Postby snaggletooth » Wed Feb 15, 2012 10:02 am
okay thanks. it turns out i just did not consider all factors. last question. if I acquire two stepper motors with a 5V 1A dependence, will it be better to use piggybacked L293DNE or a single SN754410?
snaggletooth
Postby adafruit_support_bill » Wed Feb 15, 2012 10:22 am
That's a good question. I've never done a head-to-head controlled test.
The limiting factor to piggy-backing is heat dissipation. Since steppers will be pulling the full 1A at all times - moving or standing still, I'd probably go with an SN754410 and a heat-sink.
Postby snaggletooth » Wed Feb 15, 2012 10:35 am
thanks for all of your help!
snaggletooth
Return to Arduino Shields from Adafruit
Users browsing this forum: Arne32, languer and 4 guests
New Products [103]
LEDs[109]
Cables[61]
