em-408 GPS Module...
Postby freedom » Sun Mar 25, 2012 11:23 am
Hi I bought the EM 408 module lat year and have now bought an Adafruit GPSShield v1.1, is there any way to wire this up ??
Don't mind doing it myself, but the board only comes with EM 406 + EB 85 connections…
Why no EM 408 ??
What can I do ?
freedom
Re: em-408 GPS Module...
Postby adafruit_support_bill » Sun Mar 25, 2012 2:32 pm
The tutorial is applicable to any module that has Tx, Rx, VCC and Gnd connections. http://www.ladyada.net/make/gpsshield/wiring.html
Check the 408 specs to find the pinouts: http://www.usglobalsat.com/store/download/47/em408_ug.pdf
Postby freedom » Mon Mar 26, 2012 3:06 am
adafruit_support wrote:The tutorial is applicable to any module that has Tx, Rx, VCC and Gnd connections. http://www.ladyada.net/make/gpsshield/wiring.html
Thank you so much, that is wonderful just what I need.
Is it also possible to stck on top of this unit ?
by getting the larger pins with sockets on the top ?
freedom
Postby adafruit_support_bill » Mon Mar 26, 2012 5:16 am
That you will have to determine by experimentation. I don't have a 408 module here to check.
Postby freedom » Sun Apr 15, 2012 4:42 pm
Thanks One thing the tutorial shows VCC but the module has both a PWR and and on/ off input… which one do I connect to which ?
freedom
Postby freedom » Tue Apr 17, 2012 6:42 am
adafruit_support wrote:That you will have to determine by experimentation. I don't have a 408 module here to check.
I am getting an error.
core.a(main.cpp.o): In function `main':
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:11: undefined reference to `setup'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:11: undefined reference to `loop'
freedom
Postby freedom » Tue Apr 17, 2012 8:41 am
adafruit_support wrote:What code are you trying to use?
This
http://www.ladyada.net/make/gpsshield/gpstest.html
with arduino 1.0 so no new serial just the in built.
Thanks.
freedom
Postby adafruit_support_bill » Tue Apr 17, 2012 8:57 am
Post the full text of the sketch you are using. The compiler is telling you that it can't find your setup and loop functions.
Postby freedom » Tue Apr 17, 2012 10:09 am
adafruit_support wrote:Post the full text of the sketch you are using. The compiler is telling you that it can't find your setup and loop functions.
[Edit - moderator - use the 'code' button when submitting code]
// A simple sketch to read GPS data and parse the $GPRMC string
// see http://www.ladyada.net/make/gpsshield for more info
// If using Arduino IDE prior to version 1.0,
// make sure to install SoftwareSerial from Mikal Hart
// http://arduiniana.org/libraries/SoftwareSerial/
#if ARDUINO >= 100
 #include "Arduino.h"
 #include "SoftwareSerial.h"
#else
 #include "WProgram.h"
#endif
// Use pins 2 and 3 to talk to the GPS. 2 is the TX pin, 3 is the RX pin
#if ARDUINO >= 100
SoftwareSerial mySerial = SoftwareSerial(2, 3);
#else
#endif
// Use pin 4 to control power to the GPS
#define powerpin 4
// Set the GPSRATE to the baud rate of the GPS module. Most are 4800
// but some are 38400 or other. Check the datasheet!
#define GPSRATE 4800
//#define GPSRATE 38400
// The buffer size that will hold a GPS sentence. They tend to be 80 characters long
// so 90 is plenty.
#define BUFFSIZ 90 // plenty big
// global variables
char buffer[BUFFSIZ];        // string buffer for the sentence
char *parseptr;              // a character pointer for parsing
char buffidx;                // an indexer into the buffer
// The time, date, location data, etc.
uint8_t hour, minute, second, year, month, date;
uint32_t latitude, longitude;
uint8_t groundspeed, trackangle;
char latdir, longdir;
char status;
void setup()
  if (powerpin) {
    pinMode(powerpin, OUTPUT);
  // Use the pin 13 LED as an indicator
  pinMode(13, OUTPUT);
  // connect to the serial terminal at 9600 baud
  Serial.begin(9600);
  // connect to the GPS at the desired rate
  mySerial.begin(GPSRATE);
  // prints title with ending line break
  Serial.println("GPS parser");
   digitalWrite(powerpin, LOW);         // pull low to turn on!
uint32_t parsedecimal(char *str) {
  uint32_t d = 0;
  while (str[0] != 0) {
   if ((str[0] > '9') || (str[0] < '0'))
     return d;
   d *= 10;
   d += str[0] - '0';
   str++;
  return d;
void readline(void) {
  char c;
  buffidx = 0; // start at begninning
  while (1) {
      c=mySerial.read();
      if (c == -1)
        continue;
      Serial.print(c);
      if (c == '\n')
        continue;
      if ((buffidx == BUFFSIZ-1) || (c == '\r')) {
        buffer[buffidx] = 0;
        return;
      buffer[buffidx++]= c;
void loop()
  uint32_t tmp;
  Serial.print("\n\rRead: ");
  readline();
  // check if $GPRMC (global positioning fixed data)
  if (strncmp(buffer, "$GPRMC",6) == 0) {
    // hhmmss time data
    parseptr = buffer+7;
    tmp = parsedecimal(parseptr);
    hour = tmp / 10000;
    minute = (tmp / 100) % 100;
    second = tmp % 100;
    parseptr = strchr(parseptr, ',') + 1;
    status = parseptr[0];
    parseptr += 2;
    // grab latitude & long data
    // latitude
    latitude = parsedecimal(parseptr);
    if (latitude != 0) {
      latitude *= 10000;
      parseptr = strchr(parseptr, '.')+1;
      latitude += parsedecimal(parseptr);
    // read latitude N/S data
    if (parseptr[0] != ',') {
      latdir = parseptr[0];
    //Serial.println(latdir);
    // longitude
    parseptr = strchr(parseptr, ',')+1;
    longitude = parsedecimal(parseptr);
    if (longitude != 0) {
      longitude *= 10000;
      longitude += parsedecimal(parseptr);
    // read longitude E/W data
      longdir = parseptr[0];
    // groundspeed
    groundspeed = parsedecimal(parseptr);
    // track angle
    trackangle = parsedecimal(parseptr);
    // date
    date = tmp / 10000;
    month = (tmp / 100) % 100;
    year = tmp % 100;
    Serial.print("\n\tTime: ");
    Serial.print(hour, DEC); Serial.print(':');
    Serial.print(minute, DEC); Serial.print(':');
    Serial.println(second, DEC);
    Serial.print("\tDate: ");
    Serial.print(month, DEC); Serial.print('/');
    Serial.print(date, DEC); Serial.print('/');
    Serial.println(year, DEC);
    Serial.print("\tLat: ");
    if (latdir == 'N')
       Serial.print('+');
    else if (latdir == 'S')
       Serial.print('-');
    Serial.print(latitude/1000000, DEC); Serial.print("* ");
    Serial.print((latitude/10000)%100, DEC); Serial.print('\''); Serial.print(' ');
    Serial.print((latitude%10000)*6/1000, DEC); Serial.print('.');
    Serial.print(((latitude%10000)*6/10)%100, DEC); Serial.println('"');
    Serial.print("\tLong: ");
    if (longdir == 'E')
       Serial.print('+');
    else if (longdir == 'W')
       Serial.print('-');
    Serial.print(longitude/1000000, DEC); Serial.print("* ");
    Serial.print((longitude/10000)%100, DEC); Serial.print('\''); Serial.print(' ');
    Serial.print((longitude%10000)*6/1000, DEC); Serial.print('.');
    Serial.print(((longitude%10000)*6/10)%100, DEC); Serial.println('"');
  //Serial.println(buffer);
freedom
Postby adafruit_support_bill » Tue Apr 17, 2012 10:27 am
That code compiles with no errors on 1.0 here.
Postby freedom » Tue Apr 17, 2012 11:10 am
adafruit_support wrote:That code compiles with no errors on 1.0 here.
how can I get a clean installation of the arduino software ?
freedom
Postby adafruit_support_bill » Tue Apr 17, 2012 11:38 am
Right from the Arduino site is the best place: http://arduino.cc/en/Main/Software
Where did you get the IDE you are using?
Postby freedom » Tue Apr 17, 2012 11:39 am
yes from there
freedom
Postby adafruit_support_bill » Tue Apr 17, 2012 11:51 am
Well try a fresh download. I don't see why you should be getting those errors with that source code.
Next
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 5 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
