I got me shield, assembled and it is up and running.
I used the code from "Light and Temperature logger walk through".
Spending hours i figured that the RTC is not updating time becaue for some reason the code is missing "RTC.adjust(DateTime(__DATE__, __TIME__));"
After correcting this, the time is updated.
However, i am still having trouble with RTC. For example, if the time when the code is uploaded to the card is say 10:30:10 each time when i try logging the time and date starts from 10:30:10. It means the clock is not running for some reason. Is that correct? Why is so? any advice is appreciated. Thank you.
Datalogger RTC Problem
Re: Datalogger RTC Problem
That is because the RTC.adjust is always setting the time back to when the sketch was compiled. Once the clock is running, you don't need to adjust the time (except to correct for drift - or daylight savings time). The code to use is:
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
It is all working good now.
Thanks.
Thanks.
