Is there a code possible to have the ATM328 in sleep mode idle between interrupts but with the condition to wake after preset interval.
Example:
Got to sleep_mode_idle
Interrupt > store millis() > go back to sleep_mode_idle
interrupt > Store millis() > go back to sleep_mode_idle
Wake up if sleep_mode_idle is longer than 1000ms
Within a maximum amount of 1000ms I need to take an interval measurment with the microcontroller sleeping in between.
Maybe someone has a bright idea how to code that.
Regards
Data Logger Shield current consumption results
Re: Data Logger Shield current consumption results
There are a few sleep libraries out there. Here's the one from Arduino Playground: http://playground.arduino.cc/Learning/arduinoSleepCode
- adafruit_support_rick
The CPU can't wake itself up, but you can get a Chronodot, which can be configured to produce a 1Hz square-wave output. Connect that to an external interrupt line, and it will wake the CPU every 1000ms.Lapatate wrote:Wake up if sleep_mode_idle is longer than 1000ms
EDIT: I take that back. In "Power Save" mode, Timer 2 continues to run, and it can be used to wake the CPU. From section 10.6 of the ATmega328 data sheet:
10.6 Power-save Mode
When the SM2...0 bits are written to 011, the SLEEP instruction makes the MCU enter Power-save mode. This mode is identical to Power-down, with one exception:
If Timer/Counter2 is enabled, it will keep running during sleep. The device can wake up from either Timer Overflow or Output Compare event from Timer/Counter2 if the corresponding Timer/Counter2 interrupt enable bits are set in TIMSK2, and the Global Interrupt Enable bit in SREG is set.
Thank you,
I managed to get the the MCU to exit sleep idle after 1000ms with a timer2, that's 1 step of the problem solved.
The second part:
Now in between this I need to wake up with an interrupt, store the time, and get back to sleep idle. This should be done twice but after the first interrupt the mcu doesn't get back into sleep mode idle again (althought told so) an triggers a second interrupt right away.
It might be an issue of debouncing the interrupt, or the because the first sleep mode is issued with a wake up from timer 2 interrupt and it interferrs with the second call for sleep mode idle after the signal interrupt.
Hmm..
The second part:
Hmm..
You probably have to clear the interrupt flag in the control register before you go back to sleep.Lapatate wrote:Now in between this I need to wake up with an interrupt, store the time, and get back to sleep idle. This should be done twice but after the first interrupt the mcu doesn't get back into sleep mode idle again (althought told so) an triggers a second interrupt right away.
A 5V Arduino Pro takes 0.623 milliamps at 4.6 V during the 8 second watch dog period. With it set inside a 7 time FOR loop , a blink to the LED on the board repeats about every minute drawing about 12-13 milliamps. I plan to use it with a logger shield that fits it like a Uno.
This system is going to be placed in the woods and needs to be compact although it will be in a warm environment 40-80 F). Powered by 4ea AA rechargeables it should last at least 5 months when the for loop is set for every two hours...
As you have found, the Uno is not suitable for projects like this one. (just look at my past notes on powering it for long battery life). You are using the controller chip by itself, however the Pro is USB FTDI connected with programing and resetting like the UNO.With the logger on the current goes to over 40 mills, so the for loop will be adjusted to minimize the current drain... the logger needs to be strobed only 3-4 times a day.
The best thing is it is compact and low power...
Glad to share getting started with the Pro...
stay loose as buddha
The Arduino Pro 5V 328 in sleep mode uses 0.623 ma. However, when the logger shield is connected, The SD test reads "uninitialized".
The problem was solved. it was a bad contact on the pro which when repaired put the rail on the logger and the system functions nominally...
And here is a way to extend a low power WDT for any period of time using a "for loop"
void loop()
for(int i=0; i<3; i++){ // i<3 gives a about a 16-18 second power down to 0.623mA,
// change to i<5 produces ~40 second power down...etc
// Enter power down state for 8 s with ADC and BOD module disabled
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
// 623microamps sleep 8sc plus 1 sec off blink
// 12-15 milliamps blink on
// Do something here
// Example: Read sensor, data logging, data transmission.
// Pin 13 has an LED connected on most Arduino boards.
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
delay(1000);
void loop()
delay(1000);
The logger shield runs on 5V. It has an onboard regulator to generate 3.3V for the SD card.
just thought you would like a tip about a low power arduino. The arduino Pro has the same pinouts as the Uno. With the WDT on, the power is: 0.623ma at 5V. [There is a 3V Pro version too which probably runs at less than 0.4 ma.] When the logger is added the current is over 2 ma. To reduce the logger current the power LED on the board is shut down by bending up the LED resistor (which voids the warrant). Now the total current is 1.04 ma. That is doable if operating from 4 ea AA li rechargeables. My system turns on every 4 hours to collect sensor data. I published a "FOR" program that can cycle the WDT for any period of time (a <3 cycle is about 20 sec, so a <7 is ~1 min, an hour ~<361 and 4 hour ~<1441) The batteries should last about 60-90 days.
To those using a battery system., I will archive battery system data. Please send this data:
1. controller and change to it
2. logger and change to it
3. Battery pack
4. WDT time between data collection periods
5, sensors
It will be good to let others know what can be accomplished with a self-contained system
Ken Brown AKA Bethesdakid
3. Battery pack
5, sensors
Some Thoughts,
Advantages can be expected when replacing the DS1307 against the DS1338 to extend the operation range towards lower voltages.
Currently the DS1307 timestamps for logging stop at 3.7V, whereas the SD card works down to 2.7V.
Eventually a furhter version of the logger shield could be with a migration to the MCP7940N (also low cost) for wider operation voltages.
http://ww1.microchip.com/downloads/en/D ... 02337B.pdf
Is there an other versions in planning?
Regards
Regards
Thanks for the suggestion. The board was updated fairly recently and remains one of our best sellers. I will forward your request to the design team.
the third try...5/19
In the URL: learn.adafruit.com/adafruit-data-logger-shield/using-the-real-time-clock-3
Listing the Code Walkthrough. I copied each section and put it together to program the logger.
Below is the Complete code. When compiled it returns an error message as follows:
Arduino: 1.6.8 (Mac OS X), Board: "Arduino/Genuino Uno"
___________________END SENSOR DATA LOGGING_______________
Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware "/Applications/Arduino.app/Contents/Java/hardware" -tools "/Applications/Arduino.app/Contents/Java/tools-builder" -tools "/Applications/Arduino.app/Contents/Java/hardware/tools/avr" -built-in-libraries "/Applications/Arduino.app/Contents/Java/libraries" -libraries "/Users/bethesdakid/Documents/Arduino/libraries" -fqbn=arduino:avr:uno -ide-version=10608 -build-path "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp" -warnings=default -prefs=build.warn_data_percentage=75 -verbose "/Users/bethesdakid/Documents/arduino/LOGGING_sketch_example/LOGGING_sketch_example.ino"
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware "/Applications/Arduino.app/Contents/Java/hardware" -tools "/Applications/Arduino.app/Contents/Java/tools-builder" -tools "/Applications/Arduino.app/Contents/Java/hardware/tools/avr" -built-in-libraries "/Applications/Arduino.app/Contents/Java/libraries" -libraries "/Users/bethesdakid/Documents/Arduino/libraries" -fqbn=arduino:avr:uno -ide-version=10608 -build-path "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp" -warnings=default -prefs=build.warn_data_percentage=75 -verbose "/Users/bethesdakid/Documents/arduino/LOGGING_sketch_example/LOGGING_sketch_example.ino"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/sketch/LOGGING_sketch_example.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/sketch/LOGGING_sketch_example.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/sketch/LOGGING_sketch_example.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/sketch/LOGGING_sketch_example.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/sketch/LOGGING_sketch_example.ino.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master/RTClib.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src/SPI.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "/Applications/Arduino.app/Contents/Java/libraries/SD/src/File.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "/Applications/Arduino.app/Contents/Java/libraries/SD/src/SD.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "/Applications/Arduino.app/Contents/Java/libraries/SD/src/utility/Sd2Card.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "/Applications/Arduino.app/Contents/Java/libraries/SD/src/utility/SdFile.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "/Applications/Arduino.app/Contents/Java/libraries/SD/src/utility/SdVolume.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/Wire.cpp" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src/utility/twi.c" -o "/dev/null"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/sketch/LOGGING_sketch_example.ino.cpp" -o "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI/src" "-I/Applications/Arduino.app/Contents/Java/libraries/SD/src" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire/src" "-I/Users/bethesdakid/Documents/Arduino/libraries/RTClib-master" "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/sketch/LOGGING_sketch_example.ino.cpp" -o "/var/folders/fn/y070470n6bn3jys6h4jh0b4m0000gn/T/buildad5718dd6c6304226551c3f4fc1e07e7.tmp/sketch/LOGGING_sketch_example.ino.cpp.o"
/Users/bethesdakid/Documents/arduino/LOGGING_sketch_example/LOGGING_sketch_example.ino: In function 'void setup()':
/Users/bethesdakid/Documents/arduino/LOGGING_sketch_example/LOGGING_sketch_example.ino:94:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
error("couldnt create file");
LOGGING_sketch_example:120: error: 'class SDLib::File' has no member named 'writeError'
if (logfile.writeError || !logfile.sync()) {
LOGGING_sketch_example:120: error: 'class SDLib::File' has no member named 'sync'
/Users/bethesdakid/Documents/arduino/LOGGING_sketch_example/LOGGING_sketch_example.ino:121:27: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
error("write header");
LOGGING_sketch_example:125: error: 'endif' was not declared in this scope
endif
LOGGING_sketch_example:133: error: expected ';' before 'void'
void loop(void)
LOGGING_sketch_example:151: error: 'now' was not declared in this scope
now = RTC.now();
Multiple libraries were found for "SD.h"
Used: /Applications/Arduino.app/Contents/Java/libraries/SD
Not used: /Users/bethesdakid/Documents/Arduino/libraries/SD-master
Using library RTClib-master at version 1.2.0 in folder: /Users/bethesdakid/Documents/Arduino/libraries/RTClib-master
Using library SPI at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SPI
Using library SD at version 1.0.8 in folder: /Applications/Arduino.app/Contents/Java/libraries/SD
Using library Wire at version 1.0 in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/Wire
exit status 1
'class SDLib::File' has no member named 'writeError'[/i]
//__________________INCLDES AND DEFINES___________
#include <RTClib.h> // for chatting with the real time clock
#include <SPI.h>
#include <SD.h> //SD library to talk to the card
#include <Wire.h> //Wire library seeks the i2c modules
//and chips
// A simple data logger for the Arduino analog pins
#define LOG_INTERVAL 1000 // mills between entries
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 0 // Wait for serial input in setup()
#define DateTime
// the digital pins that connect to the LEDs
#define redLEDpin 3
#define greenLEDpin 4
// The analog pins that connect to the sensors
#define photocellPin 0 // analog 0
#define tempPin 1 // analog 1
//_____________END ARDUINO digital & analog pins________
//__________________OBJECTS AND ERROR()________
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
// red LED indicates error
digitalWrite(redLEDpin, HIGH);
while(1);
//_______________END OBJECTS AND ERROR()________
//______________SETUP____________________
void setup(void)
Serial.begin(9600);
Serial.println();
#if WAIT_TO_START
Serial.println("Type any character to start");
while (!Serial.available());
#endif //WAIT_TO_START
/*now we are onto the code. We begin by initializing
*the Serial port at 9600 baud. If we set WAIT_TO_START
to anything but 0, the Arduino will wait until the
user types something in. Otherwise it goes ahead to
the next part
//________initialize the SD card___________
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
Serial.print("Logging to: ");
Serial.println(filename);
//___________END INITIALIZE SD card_______________
/*Now the code starts to talk to the SD card, it tries
* to initialize the card and find a FAT16/FAT32
* partition. */
//___________BEGIN TALK TO SD card_______________
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("millis,time,light,temp");
#if ECHO_TO_SERIAL
Serial.println("millis,time,light,temp");
#if ECHO_TO_SERIAL// attempt to write out the header to file
//___________PROGRAM ERRORS BEGIN HERE______________
pinMode(redLEDpin, OUTPUT);
pinMode(greenLEDpin, OUTPUT);
endif
#endif
#endif
// If you want to set the aref to something other than 5v
//analogReference(EXTERNAL);
//___________END TALK TO SD card_______________
//_________________MAIN LOOP____________________
//___________________TIMESTAMPING_______________
void loop(void)
// DateTime nowTHIS SUCCEEDS function-definition not allowed
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
digitalWrite(greenLEDpin, HIGH);
// log milliseconds since starting
uint32_t m = millis();
logfile.print(m); // milliseconds since start
logfile.print(", ");
#if ECHO_TO_SERIAL
Serial.print(m); // milliseconds since start
Serial.print(", ");
#endif
// fetch the time
now = RTC.now();
// log time
logfile.print(now.get()); // seconds since 2000
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
Serial.print(now.get()); // seconds since 2000
Serial.print(", ");
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.print(now.second(), DEC);
/*The first important thing is the delay() call, this
* is what makes the Arduino wait around until its time to
*take another reading. If you recall we #defined the delay
between readings to be 1000 millseconds (1 second). By
having more delay between readings we can use less power
and not fill the card as fast. Its basically a tradeoff
how often you want to read data but for basic long term
logging, taking data every second or so will result in plenty
of data!
Then we turn the green LED on, this is useful to tell us
that yes we're reading/writing data now.
Next we call millis() to get the 'time since arduino turned o
on' and log that to the card. It can be handy to have -
especially if you end up not using the RTC.
Then the familiar RTC.now() call to get a snapshot of
the time. Once we have that, we write a timestamp (seconods
since 2000) as well as the date in YY/MM/DD HH:MM:SS time
format which can easily be recognized by a spreadsheet.
We have both because the nice thing about a timestamp
is that its going to montonically increase and the nice t
hing about printed out date is its human readable
___________________END TIMESTAMPING_______________
_________________LOG SENSOR DATA____________________
int photocellReading = analogRead(photocellPin);
delay(10);
int tempReading = analogRead(tempPin);
// converting that reading to voltage, for 3.3v arduino use 3.3
float voltage = tempReading * 5.0 / 1024;
float temperatureC = (voltage - 0.5) * 100 ;
float temperatureF = (temperatureC * 9 / 5) + 32;
logfile.print(photocellReading);
logfile.println(temperatureF);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.print(photocellReading);
Serial.print(", ");
Serial.println(temperatureF);
digitalWrite(greenLEDpin, LOW);
/*This code is pretty straight forward, the processing
code is snagged from our earlier tutorial. Then we just
print() it to the card with a comma seperating the two
We finish up by turning the green LED off
Last edited by adafruit_support_rick on Thu May 19, 2016 3:53 pm, edited 9 times in total.
Reason: please use code tags (</> button)when posting code
Can you be more specific? Is this a compile-time problem, or a run-time problem.
Please post the exact code you are using and the exact text of the error messages you are seeing.
digitalWrite has been part of the standard Arduino API since the beginning, and probably will be forever. You either have a corrupted version of the code or the IDE.digitalWrite is not a recognized construct
You have a couple of warnings, which you can ignore, and some syntax errors.
You have a stray "endif" just before loop(). That's causing some other errors.
The File object doesn't have a property 'writeError', and doesn't have a method 'sync'. I don't know where you found this code.
You haven't declared 'now' as a variable.
endif
#endif
#endif
