Using the logger shield to log pwm inputs and servo deflections
Postby aerosam » Fri Apr 27, 2012 4:36 am
Hi
I have been using the sketch supplied with the logger shield and it seems to work fine.
I want to record the surface deflections on my rc aircraft. So i was planning to take a tap out of the servo potentiometers, but that would mean large wire lengths(about a meter) leading to the datashield. Is it good to transmit analog signals over this range?
I would also like to record pwm inputs from my radio and angular rates from a gyro(available as a digital signal).
I see from shieldlists that the logger shield has pins A0-A3 free. What about the digital pins, could i use them to record these values.
Wouldn't an elegant solution be to mux all these signals and send them to the logger shield?
I realize that this is more of an application of the shield, but i would appreciate some advice as i am an electronics newbie.
Sam
aerosam
Re: Using the logger shield to log pwm inputs and servo deflections
Postby adafruit_support_bill » Fri Apr 27, 2012 5:08 am
1 meter in an electrically noisy environment could be a problem. You might want to run shielded or twisted pair - and try to keep them away from your servo cables.
The shield has A0-A3 and D0-D9 available for use. With a port expanders, you could have more if needed.
Return to Arduino Shields from Adafruit
Users browsing this forum: Google [Bot] and 7 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
