RGB Shield 714/716 Installed as Shield
scottder
Post by scottder »
I am curious with this installed as a shield how does one access the other available ports, do they pass through or are they still reachable under the shield. Sorry new to arduino.
Scott
Re: RGB Shield 714/716 Installed as Shield
Unused pins are 'passed through', but it is not so convenient to solder to the tops of the header pins. Other options would be a proto-shield build with stacking headers, or a screw-shield.
You can stack one of these between the Arduino and the RGB shield and have easy access to all pins.
scottder
Post by scottder »
Hmm ok, may be easier to external mount then ( looking at this for a garduino type project. So likely I will put this in a enclosure as well. Thanks for thew quick response!
Scott
