555 frequency/voltage converter for MotorShield
Postby shi-nee » Tue May 01, 2012 1:43 pm
I've been trying to read RPM from a motor and then adjust the speed. The only code I can come up with to reliably read RPM off a Hall effect sensor is based on interrupts. I'm trying to find a schematic for a 555 based frequency converter. What I want to end up with is a variable voltage to feed into my Arduino ADC representative of the motor RPM. I've found lot's of F to V converter circuits, I'm wondering if anyone can point out the most Arduino friendly circuit?
RPM code I've been using, which is great for reading RPM. Every time I attempt to switch an output based on the variable 'rpm' I get no activity on 'motorPin'. But if I manually apply voltage to the motor I get a perfect rpm reading. If I digitalWrite motorPin HIGH in loop it will turn on the pin and still give correct rpm.
   int rpmcount = 0;
   int rpm = 0;
   int timeold = 0;
   int motorPin = 8;
   int ledPin = 13;
void setup()
   pinMode(motorPin, OUTPUT);
   pinMode(ledPin, OUTPUT);
//  digitalWrite(motorPin, HIGH);
   digitalWrite(ledPin, HIGH);
   Serial.begin(57600);
   attachInterrupt(0, rpm_fun, RISING);
void loop()
   if (rpmcount >= 20) {
     //Update RPM every 20 counts, increase this for better RPM resolution,
     //decrease for faster update
     rpm = 30*1000/(millis() - timeold)*rpmcount;
     timeold = millis();
     rpmcount = 0;
     Serial.println(rpm,DEC);
     if (rpm < 3400){
     } else {
     digitalWrite(motorPin, LOW);
     digitalWrite(ledPin, LOW);
void rpm_fun()
   rpmcount++;
   //Each rotation, this interrupt function is run twice
shi-nee
Re: 555 frequency/voltage converter for MotorShield
Postby john444 » Sat May 05, 2012 9:17 pm
Hi Shi-Nee,
A LM565 may be a much better choice. It is a phase-locked loop IC. It can be connected so as to produce a dc voltage proportional to the frequency put into it. It is an old IC (inexpensive) and there is a lot of info on it.
It has only about a 10:1 capture range but if that is good enough for your application, you might give it a try.
Good Luck
john444
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 6 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
