here I am with a new trouble
My question regards the data logger shield mounted on an arduino mega.
I got installed on my pc two different versions of the arduino IDE, the 0022 and the new 1.0 .
I updated, on the arduino 1.0 libraries directory, the RTClib to the new version and it seems to work fine.
Now, with my new 1.0 IDE I managed to compile and upload on the arduino mega a sketch that it's checked to working good if loaded with the 0022 ide version.
The problem is that I can't initialize correctly the SD card with the same sketch that works good if loaded with the old IDE.
More specifically, I mean that, in the IDE 1.0 case, the "if (!SD.begin(10))" BANNED restitutes a TRUE.
Maybe have I some updates to made in the SD.h library?
thanks for the precious help!
[FIXED] ARDUINO IDE 1.0 - SD card initializing failed
Re: ARDUINO IDE 1.0 - SD card initializing failed
Did you modify Sd2Card.h for the mega? You will need to modify this line in the IDE 1.0 libraries as well.
#define MEGA_SOFT_SPI 1
Thank you, that solved my problem!
