There is no USPS pickup on Monday Feb 15th, 2016 because of President's Day. USPS orders placed after 11am EST Fri February 12th will go out Tuesday February 16. UPS orders will ship as normal.
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
by jhyden on Wed May 23, 2012 12:28 pm
I am using a adafruit logging shield with a adafruit gps breakout board. They work great together! When I try to add an adafruilt rgb lcd shield, it stops working. Adding the #include <Adafruit_MCP23017.h> and
#include <Adafruit_RGBLCDShield.h> causes not problems but when this line in the sketch:
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield.h, the program freezes after the sd card is initialized and is ready for logging. There are no more gps nmea sentences read by the interrupt timer0.
jhyden
Re: Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
by adafruit_support_bill on Wed May 23, 2012 12:45 pm
There should be no pin conflicts since the i2c can be shared. It is possible you are running out of RAM. If you post your whole sketch we can take a closer look.
by jhyden on Wed May 23, 2012 12:54 pm
here it is:
[Edit - moderator - use 'code' button when submitting code]
// Ladyada's logger modified by Bill Greiman to use the SdFat library
// this is a generic logger that does checksum testing so the data written should be always good
// Assumes a sirf III chipset logger attached to pin 2 and 3
#include <Wire.h>
#include <SD.h>
#include <Adafruit_GPS.h>
//Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// If using Arduino IDE prior to 1.0,
// make sure to install newsoftserial from Mikal Hart
// http://arduiniana.org/libraries/NewSoftSerial/
#if ARDUINO >= 100
 #include <SoftwareSerial.h>
#else
 #include <NewSoftSerial.h>
#endif
#define OFF 0x0
#define ON 0x1
// power saving modes
#define SLEEPDELAY 0
#define TURNOFFGPS 0
#define LOG_RMC_FIXONLY 0
#define PMTK_ENABLE_WAAS       "$PMTK301,1*2E"
#define PMTK_SET_NMEA_OUTPUT_RMCGGA "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28"
#define PMTK_SET_NMEA_OUTPUT_RMCONLY "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29"
#define PMTK_SET_NMEA_UPDATE_1HZ  "$PMTK220,1000*1F"
// Use pins 2 and 3 to talk to the GPS. 2 is the TX pin, 3 is the RX pin
#if ARDUINO >= 100
 SoftwareSerial gpsSerial =  SoftwareSerial(7, 8);
#else
 NewSoftSerial gpsSerial =  NewSoftSerial(7, 8);
#endif
//Adafruit_GPS GPS(gpsSerial);
// Set the GPSRATE to the baud rate of the GPS module. Most are 4800
// but some are 38400 or other. Check the datasheet!
#define GPSRATE 9600
Adafruit_GPS GPS(&gpsSerial);
// Set the pins used
#define qualityPin 9
#define fixPin 3
#define writePin 4
#define chipSelect 10
#define BUFFSIZE 99
char buffer[BUFFSIZE];
uint8_t bufferidx = 0;
uint8_t fix = 0; // current fix data
uint8_t i;
int r;
char *pmtk;
File logfile;
// read a Hex value and return the decimal equivalent
uint8_t parseHex(char c) {
  if (c < '0')
    return 0;
  if (c <= '9')
    return c - '0';
  if (c < 'A')
    return 0;
  if (c <= 'F')
    return (c - 'A')+10;
  //WDTCSR |= (1 << WDCE) | (1 << WDE);
  //WDTCSR = 0;
  Serial.begin(9600);
  Serial.println("\r\nGPSlogger");
  pinMode(fixPin, OUTPUT);
  pinMode(writePin, OUTPUT);
  pinMode(qualityPin, OUTPUT);
  digitalWrite(qualityPin, HIGH);
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card init. failed!");
    //error(1);
  strcpy(buffer, "GPSLOG00.TXT");
  for (i = 0; i < 100; i++) {
    Serial.print('0'+i-48);
    buffer[6] = '0' + i/10;
    buffer[7] = '0' + i%10;
    // create if does not exist, do not open existing, write, sync after write
    if (! SD.exists(buffer)) {
      break;
  Serial.println(">");
  logfile = SD.open(buffer, FILE_WRITE);
  if( ! logfile ) {
    Serial.print("Couldnt create "); Serial.println(buffer);
    //error(3);
  Serial.print("Writing to "); Serial.println(buffer);
  // connect to the GPS at the desired rate
  gpsSerial.begin(GPSRATE);
  Serial.println("Ready!");
  delay(250);
  digitalWrite(qualityPin, LOW);
  //delay(100);
  // uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  //delay(100);
  // uncomment this line to turn on only the "minimum recommended" data
  //GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
  // For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
  // the parser doesn't care about other sentences at this time
  // Set the update rate
  GPS.sendCommand(PMTK_ENABLE_WAAS);
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);// 1 Hz update ratE
   //delay(100);
  //Serial.println(Serial.available(), DEC);
  char c;
  uint8_t sum;
  // read one 'line'
  if (gpsSerial.available()) {
    c = gpsSerial.read();
#if ARDUINO >= 100
    //Serial.write(c);
#else
    //Serial.print(c, BYTE);
#endif
    if (bufferidx == 0) {
      while (c != '$')
        c = gpsSerial.read(); // wait till we get a $
    buffer[bufferidx] = c;
#if ARDUINO >= 100
    //Serial.write(c);
#else
#endif
    if (c == '\n') {
      //putstring_nl("EOL");
      //Serial.print(buffer);
      buffer[bufferidx+1] = 0; // terminate it
      if (buffer[bufferidx-4] != '*') {
        // no checksum?
        Serial.print('*');
        bufferidx = 0;
        return;
      // get checksum
    if (strstr(buffer, "GPRMC")) {
      sum = parseHex(buffer[bufferidx-3]) * 16;
      sum += parseHex(buffer[bufferidx-2]);
      //Serial.println(sum, HEX);
      // check checksum
      for (i=1; i < (bufferidx-4); i++) {
        //Serial.print(i);
        //Serial.print(",");
        //Serial.print(buffer[i]);
        sum ^= buffer[i];
      if (sum != 0) {
        //putstring_nl("Cxsum mismatch");
        Serial.print('~');
        bufferidx = 0;
        return;
      // got good data!
      if (strstr(buffer, "GPGGA")) {
        // find out QUALITY
        char *r = buffer;
        r = strchr(r, ',')+1;
        r = strchr(r, ',')+1;       // skip to 3rd item
        Serial.println(r[0]);
        if (r[0] == '2') {
        } else {
      //for (int t = 1;t<100;t++) Serial.print(">");
      //Serial.println("?");
        // find out if we got a fix
        char *p = buffer;
        p = strchr(p, ',')+1;
        p = strchr(p, ',')+1;       // skip to 3rd item
        if (p[0] == 'V') {
          digitalWrite(fixPin, LOW);
          fix = 0;
        } else {
          digitalWrite(fixPin, HIGH);
          fix = 1;
      if (LOG_RMC_FIXONLY) {
        if (!fix) {
          Serial.print('_');
          bufferidx = 0;
          return;
      // rad. lets log it!
      Serial.print('#');
           // sets the digital pin as output
      // Bill Greiman - need to write bufferidx + 1 bytes to getCR/LF
      bufferidx++;
       digitalWrite(writePin, HIGH);
       logfile.write((uint8_t *) buffer, bufferidx);
       logfile.flush();
       delay(250);
      digitalWrite(writePin, LOW);
      bufferidx = 0;
      //Serial.print("idx");
       //Serial.print(bufferidx);
    bufferidx++;
    if (bufferidx == BUFFSIZE-1) {
       bufferidx = 0;
  } else {
void sleep_sec(uint8_t x) {
  while (x--) {
     // set the WDT to wake us up!
    WDTCSR |= (1 << WDCE) | (1 << WDE); // enable watchdog & enable changing it
    WDTCSR = (1<< WDE) | (1 <<WDP2) | (1 << WDP1);
    WDTCSR |= (1<< WDIE);
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);
    sleep_enable();
    sleep_mode();
    sleep_disable();
SIGNAL(WDT_vect) {
  WDTCSR = 0;
/* End code */
jhyden
by adafruit_support_bill on Wed May 23, 2012 1:15 pm
You have some good sized buffers and a lot of string-literals. I suspect that RAM is the problem. This article describes the memory limitations and some memory-saving techniques.http://itp.nyu.edu/~gpv206/2008/04/making_the_most_of_arduino_mem.html
I'd start with the strings. You can reduce the RAM footprint of any quoted strings by using the "F()" function to specify Flash-only storage - as in:
        Serial.println(F("Card init. failed!"));
by jhyden on Wed May 23, 2012 1:18 pm
my bad
I forgot, I am not reading in the interrupt but in the main loop. IN another sketch, I do read in the interrupt. But either way, I have problems.
jhyden
by jhyden on Wed May 23, 2012 1:35 pm
Will Serial.println(F()); also work lcd.println(F()); when I send to the lcd instead of the serial monitor?
jhyden
by adafruit_support_bill on Wed May 23, 2012 1:44 pm
It should work for all the quoted strings in the sketch.
by jhyden on Wed May 23, 2012 4:14 pm
That was the problem, thanks! Just one question. Adafruit_GPS returns a latitude that is a float and the sd logger needs a char string. How do I change from one to other?
jhyden
by adafruit_support_bill on Wed May 23, 2012 8:45 pm
Here is one solution to printing floats:
http://arduino.cc/playground/Code/PrintFloats
by jhyden on Wed May 23, 2012 10:32 pm
I pounded out a solution. It may not be elegant but it is simple. Since the latitude and longitude of the us is fairly consistent where I plan to use the GPS, it was easier to come up with function than trying to write one for anywhere on the earth.
// Test code for Adafruit GPS modules using MTK3329/MTK3339 driver
// This code shows how to listen to the GPS module in an interrupt
// which allows the program to have more 'freedom' - just parse
// when a new NMEA sentence is available! Then access data when
// desired.
// Tested and works great with the Adafruit Ultimate GPS module
// using MTK33x9 chipset
//    ------> http://www.adafruit.com/products/746
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
#include <Wire.h>
#include <SD.h>
// Connect the GPS Power pin to 5V
// Connect the GPS Ground pin to ground
// If using software serial (sketch example default):
//   Connect the GPS TX (transmit) pin to Digital 7
//   Connect the GPS RX (receive) pin to Digital 8
// If using hardware serial (e.g. Arduino Mega):
//   Connect the GPS TX (transmit) pin to Arduino RX1, RX2 or RX3
//   Connect the GPS RX (receive) pin to matching TX1, TX2 or TX3
// If using software serial, keep these lines enabled
// (you can change the pin numbers to match your wiring):
  SoftwareSerial mySerial(7, 8);
Adafruit_GPS GPS(&mySerial);
// If using hardware serial (e.g. Arduino Mega), comment
// out the above six lines and enable this line instead:
//Adafruit_GPS GPS(&Serial1);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences
#define GPSECHO  false
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
#define qualityPin 3
#define fixPin 2
#define writePin 4
#define BUFFSIZE 12
File logfile;
uint8_t i;
uint8_t counter = 0;
char *floatToAscii(float);
void setup()
  Serial.begin(9600);
  delay(500);
  delay(500);
  // connect at 115200 so we can read the GPS fast enough and echo without dropping chars
  // also spit it out
  lcd.begin(16, 2);
  // 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
  GPS.begin(9600);
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);   // 1 Hz update rate
  //GPS.sendCommand(PMTK_ENABLE_WAAS);    // ENABLE WAAS
  //GPS.sendCommand("$PMTK319,1*24");     // SBAS mode
  //Serial.println(F("\r\nGPSlogger"));
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(F("Card failed!"));
    //error(1);
  strcpy(buffer, "LOG00.TXT");
    //Serial.print('0'+i-48);
    buffer[3] = '0' + i/10;
    buffer[4] = '0' + i%10;
      break;
    buffer[9]=0;
  //Serial.println(F(">"));
  if( ! logfile ) {
    lcd.print(F("Couldnt create "));
    //Serial.println(buffer);
    //error(3);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print(F("Write:"));
  //lcd.clear();
  lcd.print(buffer);
  lcd.setCursor(0,1);
  lcd.print(F("Ready!"));
  useInterrupt(true);
  delay(1000);
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
  char c = GPS.read();
  // if you want to debug, this is a good time to do it!
  if (GPSECHO)
    if (c) UDR0 = c;
    // writing direct to UDR0 is much much faster than Serial.print
    // but only one character can be written at a time.
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    usingInterrupt = true;
  } else {
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
void loop()                     // run over and over again
  int CST;
  // in case you are not using the interrupt above, you'll
  // need to 'hand query' the GPS, not suggested :(
  if (! usingInterrupt) {
    // read data from the GPS in the 'main loop'
    if (GPSECHO)
      if (c) UDR0 = c;
  // if a sentence is received, we can check the checksum, parse it...
  if (GPS.newNMEAreceived()) {
    // a tricky thing here is if we print the NMEA sentence, or data
    // we end up not listening and catching other sentences!
    // so be very wary if using OUTPUT_ALLDATA and trytng to print out data
    //Serial.println(GPS.lastNMEA());   // this also sets the newNMEAreceived() flag to false
    if (!GPS.parse(GPS.lastNMEA()))   // this also sets the newNMEAreceived() flag to false
      return;  // we can fail to parse a sentence in which case we should just wait for another
  // if millis() or timer wraps around, we'll just reset it
  if (timer > millis())  timer = millis();
  // approximately every 2 seconds or so, print out the current stats
  if (millis() - timer > 6000) {
    timer = millis(); // reset the timer
    if (GPS.fix) {
    lcd.clear();
    lcd.setCursor(0,0);
      lcd.print(GPS.latitude, 4);
      lcd.print(F(" "));
      lcd.print(GPS.lat);
      lcd.setCursor(0,1);
      lcd.print(GPS.longitude, 4);
      lcd.print(F(" "));
      lcd.print(GPS.lon);
      delay(3000);
       lcd.clear();
      lcd.setCursor(0,0);
      //lcd.print("Sp");
      lcd.print(GPS.speed * 1.15078, 0);
      lcd.print(F("MPH"));
      lcd.print(F(" S:"));lcd.print(GPS.satellites);
      lcd.print(F(" Q:")); lcd.print((int)GPS.fixquality);
      //if (GPS.fixquality == 2) {  digitalWrite(qualityPin, HIGH);}
      //else {  digitalWrite(qualityPin, LOW);}
      lcd.setCursor(0,1);
      //lcd.print("An");
      lcd.print(GPS.angle, 0);
      lcd.print(F("Deg"));
      lcd.print(F(" A:"));lcd.print(GPS.altitude, 0);
      lcd.print(F("Ft"));
      bufferidx = 11;
      //Serial.println(GPS.latitude, 4);
      char *buffer = floatToAscii(GPS.latitude);
      //strcpy(buffer, "00,testing\r\n");
      logfile.flush();
  delay(250);
    else {lcd.print(F("Searching..."));}
char *floatToAscii(float lat)
float temp =0;
int v1, val2, val3, v4, val5, val6, val7, val8;
  temp = lat*10000;
  //Serial.println(temp);
  v1 = (temp/10000000);
  buffer[0] = v1+48;
  temp = (temp-((float)v1*10000000));
  //Serial.println(v1);
  val2=(temp/1000000);
  buffer[1] = val2+48;
  temp = (temp-((float)val2*1000000));
  //Serial.println(val2);
  val3=(temp/100000);
  buffer[2] = val3+48;
  temp = (temp-((float)val3*100000));
  //Serial.println(val3);
  v4=(temp/10000);
  buffer[3] = v4+48;
  buffer[4] = '.';
  temp = (temp-((float)v4*10000));
  val5=(temp/1000);
  buffer[5] = val5+48;
  temp = (temp-((float)val5*1000));
  //Serial.println(val5);
  val6=(temp/100);
  buffer[6] = val6+48;
  temp = (temp-((float)val6*100));
  //Serial.println(val6);
  val7=(temp/10);
  buffer[7] = val7+48;
  temp = (temp-((float)val7*10));
  //Serial.println(val7);
  val8=(temp/1);
  buffer[8] = val8+48;
  buffer[9]='\r';
  buffer[10]='\n';
  buffer[11]=0;
  return buffer;
jhyden
by jhyden on Fri Jun 01, 2012 9:06 am
My final sketch:
    //John Hyden
    //June 1, 2012
    // Based on the test code for Adafruit GPS modules using MTK3329/MTK3339 driver
    //and the Adafruit lcd Shield test sketch and the Adafruit data logging test sketch
    // desired.
    #include <Wire.h>
    #include <SD.h>
    // off by default!
    #define fixPin 5
    #define writePin 4
    #define BUFFSIZE 30
    File logfile;
    uint8_t i;
    uint8_t counter2 = 0;
    void setup()
      Serial.begin(9600);
      delay(500);
      delay(500);
      // also spit it out
      lcd.begin(16, 2);
      GPS.begin(9600);
        lcd.clear();
        lcd.setCursor(0,0);
        //error(1);
          break;
        buffer[9]=0;
      if( ! logfile ) {
        //error(3);
      lcd.clear();
      lcd.setCursor(0,0);
      //lcd.clear();
      lcd.print(buffer);
      lcd.setCursor(0,1);
      useInterrupt(true);
      delay(1000);
      if (GPSECHO)
        if (c) UDR0 = c;
      if (v) {
        OCR0A = 0xAF;
      } else {
      int CST;
        if (GPSECHO)
          if (c) UDR0 = c;
        if (GPS.fix) {
        lcd.clear();
        lcd.setCursor(0,0);
          if (counter >= 255) {counter2++;}
          counter++;
          if (counter == 0){counter = 1;}
          lcd.print(F(" "));
          lcd.print(GPS.lat);
          lcd.print(F(" "));
          lcd.print(counter2);
          lcd.setCursor(0,1);
          lcd.print(F(" "));
          lcd.print(GPS.lon);
          lcd.print(F(" "));
          lcd.print(counter);
          delay(3000);
           lcd.clear();
          lcd.setCursor(0,0);
          //lcd.print("Sp");
          lcd.setCursor(0,1);
          //lcd.print("An");
          lcd.print(F(" A:"));lcd.print(GPS.altitude*3.2808399, 0);
          lcd.print(F("Ft"));
          bufferidx = BUFFSIZE;
          char *buffer = floatToAscii(GPS.latitude, GPS.longitude);
          logfile.flush();
      delay(250);
    char *floatToAscii(float lat, float lon)
    float temp =0;
    int v1, val2, val3, v4, val5, val6, val7, val8, x=0;
      temp = lat*10000;
      buffer[0] = v1+48;
      buffer[2] = ',';
      val3=(temp/100000);
      buffer[3] = val3+48;
      v4=(temp/10000);
      buffer[4] = v4+48;
      buffer[5] = '.';
      val5=(temp/1000);
      buffer[6] = val5+48;
      val6=(temp/100);
      buffer[7] = val6+48;
      val7=(temp/10);
      buffer[8] = val7+48;
      temp = (temp-((float)val7*10));;
      val8=(temp/1);
      buffer[9] = val8+48;
      buffer[10]=',';
      buffer[11]='N';
      buffer[12]=',';
      temp = lon*10000;
      if (temp > 100000000){
        buffer[13] = '1';
        x=1;
        temp = temp - 100000000;
      buffer[13+x] = v1+48;
      buffer[14+x] = val2+48;
      buffer[15+x] = ',';
      val3=(temp/100000);
      buffer[16+x] = val3+48;
      v4=(temp/10000);
      buffer[17+x] = v4+48;
      buffer[18+x] = '.';
      val5=(temp/1000);
      buffer[19+x] = val5+48;
      val6=(temp/100);
      buffer[20+x] = val6+48;
      val7=(temp/10);
      buffer[21+x] = val7+48;
      val8=(temp/1);
      buffer[22+x] = val8+48;
      buffer[23+x]=',';
      buffer[24+x]='W';
      buffer[25+x]='\r';
      buffer[26+x]='\n';
      buffer[27+x]=0;
      return buffer;
jhyden
by jhyden on Fri Jun 01, 2012 10:17 am
the gps lat and long format that i am writing to the logger looks like this:
42,58.2000,N,87,54.1104,W
42,58.2008,N,87,54.1104,W
I can then take the file into excel and easily create a decimal degree format for lat and long if I want or any number of other possibilities.
jhyden
cron
