Can motor shield drive brushless DC motors?
- peridot
The difference between a brushless DC motor and a stepper motor has never been very clear to me; it seems like they're each a set of windings around a ring of magnets. The physical design is presumably somewhat different, but it makes me wonder: can the motor shield be used to drive a brushless DC motor? For example, I have a number salvaged from dead hard drives that have four wires, one common wire and one at the other end of each of three windings ("wye configuration").
Re: Can motor shield drive brushless DC motors?
Driving a brushless motor is similar to driving a stepper. Most have hall-effect sensors for feedback on rotational position/speed. Not sure what feedback (if any) is used in hard-drive motors.
A while back, someone posted that he had success doing this. But I don't recall the details.
- peridot
Among the ones I've opened, hard drive motors have no sensors (back EMF sensing? dead-reckoning? feedback via the read head?), but CD-ROM and floppy drive main motors do have Hall effect sensors. I was thinking of the simplest case, just commanding a speed and trusting the motor to catch up. I'll look through the archives, thanks.
For posterity, as it were: http://forums.adafruit.com/viewtopic.ph ... 83&p=67065
Technically, steppers are a sub-category of brushless motors. The only difference I've seen is that 'stepper' usually means the coils are outside the rotor, and 'brushless' means the coils are inside the rotor.peridot wrote:The difference between a brushless DC motor and a stepper motor has never been very clear to me; it seems like they're each a set of windings around a ring of magnets.
Steppers also tend to be 'reluctance motors', which have a rotor that looks like a gear. When a coil has current flowing through it, it pulls the nearest tooth closer. Brushless DC motors tend to use a magnetic strip for the rotor.
The control process should be pretty much the same though.
- armohseni
HI
i have one question
i have many old VHS video BLDC.
how i can drive them with the v3 of the shield?
thank from advanced
i have one question
thank from advanced
We have not attempted that here and do not have any information on how to do it.
