RGB LCD shield kit with arduino mega 2560
julienbeaumont
Post by julienbeaumont »
Hi, i'm starting in arduino, i bought a Mega 2560 and a rgb lcd controller (http://www.adafruit.com/products/714)
I can't get it to work, I tried to compare the pin position with the picture of a uno but I don't have any result, can someone tell me precisely wich pin i must plug and where ?
Re: RGB LCD shield kit with arduino mega 2560
Post by adafruit »
Is it an R3 Mega?
julienbeaumont
yes
Post by adafruit »
Can you post up a photo showing your shield and mega connected - top and sides please.
julienbeaumont
here is the first part
photo 3.JPG (139.87 KiB) Viewed 1618 times
photo 2.JPG (128.17 KiB) Viewed 1618 times
photo 1.JPG (168.95 KiB) Viewed 1618 times
julienbeaumont
and these ones. Thank you for your help.
photo 5.JPG (127.02 KiB) Viewed 1615 times
photo 4.JPG (124.96 KiB) Viewed 1615 times
Post by adafruit »
connect the SCL and SDA pins from the top left corner of the shield to the SCL/SDA pins on the top left corner of the MEGA - they're next to AREF
do not connect digital 4 and 5
julienbeaumont
if you mean this, it doesn't work...
photo 2.JPG (123.91 KiB) Viewed 1595 times
photo 1.JPG (149.94 KiB) Viewed 1595 times
Top left, not top right. Looking from the face side of the shield.
julienbeaumont
did it too, was my first try ! doesn't work !
julienbeaumont
ok, i got the backlight working, i uploaded the program hello world, the color is changing but no text on screen...
Are you sure you didn't have SDA and SCL reversed? SCL is the pin on the far left end and SDA is the second pin in.
julienbeaumont
If i reverse the pins i got nothing.
If the backlight is working, you are communicating with the shield. The missing text is an indication of a soldering problem on the shield. Post clear photos of the front and back of the shield.
julienbeaumont
As far as I can see, I don't notice faulty soldering...
photo 2[1].JPG (856.27 KiB) Viewed 1589 times
photo 1[1].JPG (691.63 KiB) Viewed 1589 times
