Hi, i have just started with arduino and wanted to muck around with the ethernet shield. I purchased both of the following items:
http://www.adafruit.com/products/201
http://www.adafruit.com/products/563
and seen as though the ethernet shield is said to be mega compatible i assumed it would work with the mega ADK but the pins do not appear to line up. To get the board to fit on (including the ICSP pins) i end up with the end 2 pins on both sides having no where to go. The missing pins are IQREF and an unlabelled pin on one side and SDA, SCL on the other. I cant see anywhere on the Mega ADK with those pins so where do they get wired up to? are they needed? Thank you for any help you can offer.
Adrian
