Hi all,
I've faced an issue, when I using only one DC motor, everything works like a charm,
but if I connect two motors simultaneously, one motor works OK, but another in few times slower.
(currently I'm using Arduino 2560 MEGA board)
Any help is appreciated,
thanks.
Motor Shield Issue with DC Motors
Re: Motor Shield Issue with DC Motors
What motors are you using and how are you powering them? Is the slower motor always on the same port?
I use DC Motor260 two pcs., one of them I connect to the M1 port, and another to M2.
I supply motors with two separate sources - from Arduino, and extra - with 9V from battery.
I've tried to connect motors to different ports - seems to be the same result.
Do you have a link to a product spec for that?I use DC Motor260 two pcs
Not a good idea. You should use one or the other.I supply motors with two separate sources - from Arduino, and extra
Is that a 9v battery pack, or one of those little rectangular 9v batteries? The small rectangular ones are all but worthless for driving motors.- with 9V from battery.
If you swap motors and/or swap ports, is it always the same motor that is running slow? What if that is the only motor connected?I've tried to connect motors to different ports - seems to be the same result.
thanks for reply,
I'll check and update you with results.
Also I have a question, what is the best solution for supplying motors?
(only from extra source? if yes, what kind of power cell I have to use?)
thanks
thanks
something like this:Do you have a link to a product spec for that?
http://www.alibaba.com/product-gs/42626 ... Motor.html
Look here. Scroll down to the section "Powering Your Motor".what is the best solution for supplying motors?
