ok thank you,
Any ideas of my problem ? What kind of command can I do to test the cable or my wire or the shield ?!
NFC Shield for Arduino - PN532 & LibNFC
- adafruit_support_rick
Re: NFC Shield for Arduino - PN532 & LibNFC
I consulted our PN532 expert, and he seems to think that this is a driver problem with your USB/Serial adapter. That's why you're seeing this error:
nfc-list: ERROR: Unable to open NFC device: pn532_uart:/dev/ttyUSB0
Does this command show the device?
ls /dev/ttyUSB*
No problem with the driver (see the dmesg output).
So I think it's about my connections between the wires and the shield.
But what can I do better to make it work ?
(sorry for the delay of the answer)
lsusb output :
dmesg output :
lsusb output :
Bus 002 Device 104: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0403 Future Technology Devices International, Ltd
idProduct 0x6001 FT232 USB-Serial (UART) IC
bcdDevice 6.00
iManufacturer 1 FTDI
iProduct 2 USB <-> Serial Cable
iSerial 3 AFU7ZWK8
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
BANNED 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2 USB <-> Serial Cable
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
# dmesg
[35815.125199] usb 2-1.2: new full-speed USB device number 104 using ehci-pci
[35815.224696] usb 2-1.2: New USB device found, idVendor=0403, idProduct=6001
[35815.224700] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[35815.224703] usb 2-1.2: Product: USB <-> Serial Cable
[35815.224705] usb 2-1.2: Manufacturer: FTDI
[35815.224707] usb 2-1.2: SerialNumber: AFU7ZWK8
[35815.261058] usbcore: registered new interface driver usbserial
[35815.261090] usbcore: registered new interface driver usbserial_generic
[35815.261138] usbserial: USB Serial support registered for generic
[35815.262516] usbcore: registered new interface driver ftdi_sio
[35815.262536] usbserial: USB Serial support registered for FTDI USB Serial Device
[35815.262688] ftdi_sio 2-1.2:1.0: FTDI USB Serial Device converter detected
[35815.262731] usb 2-1.2: Detected FT232RL
[35815.262734] usb 2-1.2: Number of endpoints 2
[35815.262737] usb 2-1.2: Endpoint 1 MaxPacketSize 64
[35815.262739] usb 2-1.2: Endpoint 2 MaxPacketSize 64
[35815.262741] usb 2-1.2: Setting MaxPacketSize 64
[35815.263171] usb 2-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
[35816.540852] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[35816.544241] JFS: nTxBlock = 8192, nTxLock = 65536
[35816.553383] NTFS driver 2.1.30 [Flags: R/W MODULE].
[35816.561906] QNX4 filesystem 0.2.3 registered.
[35816.565840] xor: automatically using best checksumming function:
[35816.604916] avx : 22802.000 MB/sec
[35816.672913] raid6: sse2x1 6423 MB/s
[35816.740903] raid6: sse2x2 7916 MB/s
[35816.808889] raid6: sse2x4 9000 MB/s
[35816.808891] raid6: using algorithm sse2x4 (9000 MB/s)
[35816.808893] raid6: using ssse3x2 recovery algorithm
[35816.814643] bio: create slab <bio-1> at 1
[35816.814795] Btrfs loaded
[35817.010506] device-mapper: uevent: version 1.0.3
[35817.010587] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email protected]
I add that I'm using a 5V FTDI friends, but I power it through the arduino. And connect the ground wire to the black cable of the FTDI friend.
I can't open your pictures anymore - they want me to log in to something. Can you post them here? Use the "Upload Attachment" tab.
Ok, sorry about that.
> Just to let you know, I tried TX / RX on the yellow cable and orange (vice verca too), and on the brown and red.
- IMG_20131008_231524_resize.jpg (101.81 KiB) Viewed 1962 times
- IMG_20131008_231635_resize.jpg (126.06 KiB) Viewed 1962 times
I think the problem is your FTDI cable. You should be able to run
and see serial data show up in your terminal window. I just tried that with the same cable you are using, and got nothing.
I then tried the same thing with this 4-pin cable: http://www.adafruit.com/products/954 , and got the expected results.
The only difference is that the six-pin cable has two handshaking lines, RTS and CTS. I tried grounding those, powering those, and shorting them together, but I still got nothing. I have no explanation - it should work, but it doesn't. I must be missing something, but I don't know what.
You can try it. I just wrote a little sketch to print out "Hello" in the loop. I attached the cable to arduino TX. I even tried powering the arduino from the cable's 5V and GND.
As I said, it works with the 4-pin cable, but not with the 6-pin.
cat /dev/ttyUSB0
void setup()
Serial.begin(9600);
void loop()
Serial.println("Hello!");
delay(500);
Ok
Great thanks to you !
I'm gonna get another FTDI cable.
Thank you.
Thank you.
Same problem with my new cable.
I verify my solders, with a multimeter, and I close the SEL0 and open the SEL1.
The pins are Ok, but still have the Timeout
I tried to search the datasheet http://www.adafruit.com/datasheets/PN53 ... c_v1.0.pdf
But there is only the one of the breakout board and not the shield.
Is it the SEL0 close and SEL1 open ?
Is it the SS for RX (uart) and MOSI for TX ?
I see in the datasheet it should be the pin24 (P30/UART_RX), and the pin 28!?
SEL0 closed, SEL1 open
Connect MOSI/SDA to RX pin of cable
Connect NSS/SCL to TX pin of cable
I begin to lose hope of making it work.
I attached two pics. I really don't get what I'm doing wrong.
I double checked my solders with a multimeters.
Can it be about the libnfc ? I downloaded the source libnfc-1.7.0-rc7.tar.gz and compile it for the pn532_uart.
- back_board.jpg (105.51 KiB) Viewed 1805 times
- Front_board.jpg (122.92 KiB) Viewed 1805 times
I seem to recall some incompatibility with libnfc-1.7. You may want to downgrade to an earlier version.
What operating system are you using? We have some specific instructions for linux and MacOSX here:
http://learn.adafruit.com/adafruit-pn53 ... nfc/libnfc
I'm under Debian Jessie (linux).
I'm gonna try this evening with an earlier version then.
Thank you for your answer.
nothing changed
If you have any other hint ? ideas ?
Version 1.7.0
Version 1.6.0.1
Version 1.5.1
Version 1.4.0
Version 1.3.2
and it's not the cable. Neither the solder...
Version 1.7.0
# ./nfc-poll
/root/Projects/libnfc-1.7.0/examples/.libs/lt-nfc-poll uses libnfc 1.7.0
pn53x_check_communication: Timeout
lt-nfc-poll: ERROR: Unable to open NFC device.
# ./nfc-
nfc-anticol nfc-dep-target nfc-emulate-tag nfc-poll
nfc-dep-initiator nfc-emulate-forum-tag2 nfc-emulate-uid nfc-relay
# ./nfc-poll
/root/Projects/libnfc-1.6.0-rc1/examples/.libs/lt-nfc-poll uses libnfc 1.6.0-rc1 (r1326)
# ./nfc-poll
/root/Projects/libnfc-1.5.1/examples/.libs/lt-nfc-poll uses libnfc 1.5.1 (r1175)
pn53x_check_communication: Operation timed-out
No NFC device found.
# ./nfc-list
/root/Projects/libnfc-1.4.0/examples/.libs/lt-nfc-list use libnfc 1.4.0 (r833)
lt-nfc-list: ERROR: Unable to wakeup the PN532.
lt-nfc-list: ERROR: Unable to receive data. (RX)
# ./nfc-list
/root/Projects/libnfc-1.3.2/src/examples/.libs/lt-nfc-list use libnfc 1.3.2 (r294)
ERROR: Unable to connect to NFC device.
[149145.516467] usb 2-1.1.1.4: new full-speed USB device number 53 using ehci-pci
[149145.609789] usb 2-1.1.1.4: New USB device found, idVendor=067b, idProduct=2303
[149145.609802] usb 2-1.1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[149145.609808] usb 2-1.1.1.4: Product: USB-Serial Controller
[149145.609814] usb 2-1.1.1.4: Manufacturer: Prolific Technology Inc.
[149145.610182] pl2303 2-1.1.1.4:1.0: pl2303 converter detected
[149145.611835] usb 2-1.1.1.4: pl2303 converter now attached to ttyUSB0
I don't think you posted any pictures of the soldering on RX and TX. The solders on some of your other pins look a little solder-starved. Post a picture of RX and TX.
Also, you should have a ground connection from the FTDI to the shield.
