I've just built a v1.1 Wave Shield kit. It works perfectly with my old Arduino (Diecimila board upgraded to a 328) using a couple of different SD cards, but gives an initialisation error running on a Uno board -
card.init failed
SD error
errorCode: 1
errorData: FF (sometimes 0)
This is using the SdReadTest program from the WaveHC library in Arduino 1.0 (under Ubuntu 12.04). Playback of audio files with daphc is also fine using the Diecimila. I know I can just carry on using the Diecimila - but faults like this bug me and I'd like to understand what's going wrong on the Uno! I don't think it's a construction fault - I've checked the shield thoroughly, and anyway it always works with the 'right' Arduino.
Any pointers for things to try, or online references (I've searched but could find anything) will be gratefully received.
Chris
WaveShield OK with Diecimila, not with Uno
Re: WaveShield OK with Diecimila, not with Uno
Try running the "cardinfo" sketch from the SD library. It gives more detailed diagnostic messages.
- cearnsh
Cardinfo with the WaveShield on the Uno gives -
Initializing SD card...initialization failed. Things to check:
* is a card is inserted?
* Is your wiring correct?
* did you change the chipSelect pin to match your shield or module?
The same shield/card on the Diecimila gives -
Initializing SD card...Wiring is correct and a card is present.
Card type: SD1
Volume type is FAT16
Volume size (bytes): 63283200
Volume size (Kbytes): 61800
Volume size (Mbytes): 60
Files found on the card (name, date and size in bytes):
(-- lists all the files on the card --)
So the behaviour is at least consistent between the different sketches...
Card type: SD1
Interesting symptoms. Not sure what is going on there
As far as the wave shield is concerned, there shouldn't be much difference between an Diecimila with a 328 and an UNO. The SD card SPI interface uses pins 10-13. It is possible that there is either an electrical or physical problem with the UNO that prevents proper operation of one or more of those pins.
Have you tried the UNO with any other SPI devices or shields?
- cearnsh
A similar thought had occurred to me. I have an ethernet shield but had not previously used the microSD card slot. That also works fine with the Diecimila but not the Uno. So it looks like the WaveShield is in the clear but there's a big cloud over the Uno
I don't have any other SPI devices but will look into other ways to test the Uno board. The only other thing is that I removed the resistor to disable the on-board LED on the Diecimila. This surely it can't be significant though - most Arduinos have this circuit in place.
Many thanks for your help - and I'm glad it wasn't the WaveShield at fault!
Chris
Chris
- pburgess
I hate to be That Guy™, but is the Uno in question the real deal or an eBay BANNED?
- cearnsh
Always worth asking these things - but it is the Genuine Article.
